Throtte Position Sensor (TPS) Replacement
Old Dec 2, 2010 | 03:57 AM
chewi's Avatar
Hi all,
I had to scan my 2003 TL-S for an error code as my VSA and Engine lights were on and my shifting became really rough.
It came out with 1 code that said i needed to replace the TPS. We called acura about the part and it will cost $600 because they can only sell the entire Thottle body with the sensor.
Has anyone purchased and installed an aftermarket TPS that fixed the issue?
I saw one online somewhere made by OMNI that fits multiple hondas and acuras.
Can someone chime in here and let me know your experience and what is your suggestion?
Old Dec 2, 2010 | 09:25 AM
fsttyms1's Avatar
you will have to cut slots into the stock rivets to remove them like a screw, then you will need a multi meter and spend some time getting it set where it needs to be. (its not as simple as unscrew replace and you are ready to go. A few others have done it.
Old Dec 2, 2010 | 10:47 AM
NSXNEXT's Avatar
I replaced mine.
As Kris said, you take a dremel and cut slots into the "rivets" that hold it down. They are bolts that the heads are snapped off. So cutting the slots allow you to unscrew them with a flat blade screwdriver.
Clean off the old gasket material and install the new gasket. Then install the TPS, leaving the new bolts (allens) on loosely so you can adjust the sensor. Reconnect plug.
You'll need a ohm meter to calibrate it. Basically you turn the TPS a little bit at a time until you get the right ohm reading (.45). It says volts in the instructions but that's wrong.
Installation instructions: http://www.omnipowerusa.com/tps_install_b.doc
Old Dec 3, 2010 | 11:03 AM
01tl4tl's Avatar
our Masters to the rescue once again!!
I was going to suggest the auto recycler yard for a used TB assembly or the TPS from one
certainly worth a phone call
Old Dec 6, 2010 | 10:41 PM
chewi's Avatar
Thanks everyone for the replies. Did you all buy the TPS from eBay or is there a website you'd recommend?
Old Dec 7, 2010 | 07:17 AM
totaledTL's Avatar
You can buy from the website mentioned-
Old Dec 7, 2010 | 10:03 AM
cantubury's Avatar
i am contemplating buying a near-perfect 2003 TL-S fully maintained but i am afraid the transmission will go. my 2002 blew but Gettle, srq gave one free ($2750) but i dont think this one i am looking at qualifies. did you have any transmission problems in addition to this this throttle valve prob. thx
Old Dec 7, 2010 | 10:56 AM
01tl4tl's Avatar
you can call acura 1 800 382 2238 x5 tell them doing a `pre buy inspection` and recall and warranty repair ck
strangely, they dont always know if the trans was replaced~ only that it got the recall installed external oil jet kit
So look at the bolt heads on trans bolts--blue paint is acura warranty exchange trans
there were improvements with the post 2005 replacements, but no fix ever made fully.
03 has the same probs as 00-2005!!!! but many 03 are not part of the trans extended warranty VIN range
you can ask the 800 person about that too--are you covered?
Old Dec 7, 2010 | 10:57 AM
01tl4tl's Avatar
how is $2750 free?
Old Dec 7, 2010 | 03:31 PM
NSXNEXT's Avatar
IIRC Omnipower is the only supplier of those. I think all of the Ebay auctions are theirs.
I've purchased two of them (one for me, one for someone else) from them with no problems. Check ebay, occasionally they drop their price for an auction or two.
Old Dec 8, 2010 | 11:09 AM
01tl4tl's Avatar
never hurts to contact seller and ask for a special hardship/goodwill deal
you never know what people will do for you in the spirit of the holidays!
Old Aug 22, 2013 | 09:27 PM
Rick Thompson's Avatar
4th Gear
Omnipower
Just so you all know, Omnipower no longer stocks Throttle Position Sensors for Acuras.
Old Aug 23, 2013 | 11:40 AM
TLer trash's Avatar
I recall reading about other companies that offer them now. I can't recall the specifics, but it might have been dorman, or someone like that. Possibly car-quest or napa.
Old May 10, 2020 | 01:47 PM
superpap56's Avatar
blox racing supplies them https://bloxracing.com/shop/ i just bought one from them
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
NSolace
Sep 3, 2015 08:02 PM
