TCS light is always on
Old Jul 12, 2011 | 10:56 AM
SarahSTAR401's Avatar
Ok so a couple weeks ago my caliper got stock on the my rear passenger side but i didnt change it right away. Is it possible that it effed up the sensor not that i know where the sensor is located but im just asking.
Old Jul 12, 2011 | 01:01 PM
Karanx7's Avatar
Unregistered Member
Press the TCS button?
Old Jul 12, 2011 | 06:14 PM
01tl4tl's Avatar
I will agree with wheel speed sensor damaged,,could have torn the wire or heat melted sensor lead...
pull the wheel and look behind the hub for a toothed gear and small sensor
Old Jul 12, 2011 | 06:15 PM
01tl4tl's Avatar
thats assuming you tried the button already
Old Jul 12, 2011 | 11:51 PM
come on guys i know im a girl but of course i pushed the button! lmfao. Okay i will try to look at it soon. Its not an issue if i dont change it though is it?
Old Jul 13, 2011 | 09:49 AM
01tl4tl's Avatar
you would be surprised how many new to the car think the light ON means system good and standing by!
gender aside- plenty of men have made stranger mistakes!
TCS is front wheel speed control thru use of brakes on faster/spinning wheel-up to 16mph
so I would look at the sensors there
pretty common failure actually, sometimes on its own from rust, or by careless action during front brake job = tears the wire to sensor
Old Jul 13, 2011 | 11:51 AM
Okay i definitely agree about the stranger mistakes part. hahaha.
Anyways what your saying is TCS only controls front two wheels? so the sensor should be on the front tires? anyone know how much it costs to take to someone and have them do it? or how much acura would charge to fix?
Old Jul 13, 2011 | 03:38 PM
01tl4tl's Avatar
acura wont treat you right,,look for a private shop ad in phone book- honda acura listed as cars they normally work on
Its pretty simple parts swap if wheel speed sensor is broken
a code reading will tell if thats the case
TCS Traction Control only works below 16mph /25kph
the computer picks up a differance in rotation speed of the front wheels and applies the brake rapidly on and off to the offending faster wheel
Its guessing you are on ice or similar and just starting to move forward
Old Jul 13, 2011 | 03:41 PM
01tl4tl's Avatar
if you live in the usa -except Ca, parts stores will do a code read for free
report whatever letter number combo back here
Old Mar 20, 2012 | 11:53 PM
kalick's Avatar
7th Gear
mines is on also hmmm makes does this make any different in driving maneuverability ??
Old Mar 21, 2012 | 08:17 AM
fsttyms1's Avatar
GET the codes read. We cant help you fix the issue if we dont know whats wrong. Warning lights on the dash can mean MANY things.
Yikes
May 3, 2021 04:29 PM
Retep Nitciaj
1G RL (1996-2004)
Sep 18, 2015 10:26 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Allen_442
Sep 8, 2015 06:01 PM
