TCS after transmission fluid change
Old Sep 24, 2009 | 09:58 PM
Eddystone's Avatar
I changed my transmission fluid recently with Honda ATF-Z1 (just 3qts) and 3 days later the TCS lights comes on while driving. Whats going on? What should I do? its long out of warrenty. When the light came on the car felt weird driving, would shift awkwardly. I am scared because I read that when the TCS light comes on it could be that the transmission is just about to die.
Old Sep 24, 2009 | 10:10 PM
gold2003tl (90)'s Avatar
2003 TL-p
whens the last time the fluid was changed? does the tranny slip or shutter?
Old Sep 24, 2009 | 10:13 PM
Eddystone's Avatar
3qts was change around last October. The tranny does slip a little before the recent fluid change but its worst now like it would really skip hard. I know that I am due for a new transmission but it wasn't that bad until now.
Old Sep 25, 2009 | 12:08 AM
Did you check the fluid level with the engine running after the change?
Old Sep 25, 2009 | 12:29 AM
Eddystone's Avatar
I checked it when the engine was off and warm and it was right at the top mark. Should I recheck it when the engine is on?
Old Sep 28, 2009 | 10:59 PM
Yes, the transmission fluid dip-stick should be checked with the engine running. Most likely you might have over-filled or under-filled the atf. Good luck.
Old Sep 29, 2009 | 01:48 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Do u see what code came up with a OBII reader?
Old Sep 30, 2009 | 09:37 PM
totaledTL's Avatar
Acura o/m states to check the fluid w/ engine OFF.
https://acurazine.com/forums/showthr...ighlight=level
Old Oct 7, 2009 | 04:29 PM
Eddystone's Avatar
Checked it and its just perfect, right on the top dot/just a tiny bit below it.
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
nanos
Nov 12, 2015 08:41 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
quake97
Aug 30, 2015 07:57 PM
