TCS and ABS light is on
I drive a 99 3.2 TL with 162k miles. I JUST had the tranny replaced for the 2nd time, the problem is that my TCS and ABS light is on and i dont know why. My CEL is not on. I had my brakes done about a month ago. Can anybody please give me some insight?
Chk. wheel sensors.
take it to a parts store for free code reading--that will help us eliminate some possibles
then call the trans shop and tell them the lights are on--take it back and let them hook up whatever wire is loose
the lights can mean 100+ things
Here are the 100+ reasons (from the service manual):
• For ABS or TCS Indicator:
- Only drive wheels rotate
- One drive wheel is stuck
- The vehicle goes into a spin.
- The ABS continues to operate for a long time.
- The vehicle is subjected to an electrical signal disturbance.
• For TCS Indicator:
- The TCS operated when the front brake pad temperature was excessively high.
- The TCS switch is OFF.
- One or more of these components are faulty:
Heated oxygen sensor,
Manifold absolute pressure sensor,
Crankshaft position sensor,
Engine coolant temperature sensor,
Throttle position sensor,
Top dead center sensor,
Top dead center sensor 2,
Intake air temperature sensor,
Exhaust gas recirculation,
Barometric pressure sensor,
Idle air control valve,
VTEC pressure switch,
Knock sensor,
Fuel supply system,
Automatic transaxle,
Misfire detection system of the PGM-FI system
...that's why getting the code(s) would really help. I don't know if the usual parts stores (AutoZone, Advance, etc.) have scanners that will read ABS codes. You can retrieve the codes yourself if you are comfortable sticking wires in the OBDII port.
Knock sensor,
Fuel supply system,
most parts store scanners wont get the secret abs codes,,
acura has a special scanner for them, or a brake specialty repair shop will
ok wow that was very helpful!! i called the dealer they want like almost $200 to check it! Im gonna try an auto parts store then check back in with you guys, thanks sooo much <3
why isnt it back at the trans shop?
a wire or something got loose or left off and triggered the warning lights
They worked on it- they are responsible
acura phone person gave the standard line- diagnostics 1.5 hours~
I have a 2000 TL and both my TCS and ABS lights are on but the dealership I brought it from back in 2008 called the Acura dealership and they said it was sensors and a recall so you might want to see what they say. Hope this helps.
can you elaborate on what they told you about sensors and warranty??
mada51589
05-03-2022 08:54 PM
