Tail Lights Not turning on with Headlights
Old Jul 17, 2010 | 02:07 AM
kinghost1's Avatar
I recently tried to fixed my left parking light, and in the process of resodering a loose connection---Both parking lights do not turn on, they only signal.
Furthermore, I have noticed that my rear tail lights do not turn on when my headlights are on in parking mode and fully on. There is also no dash lights or CD player lights.
If anyone knows what could be wrong Id greatly appreciate it.!
Old Jul 17, 2010 | 12:01 PM
01tl4tl's Avatar
the obvious would be to remove what you `fixed` and redo the wires so they are not touching and causing these issues
What caused the repair anyway--that may be our clue
ck ground wires for each part
may have a bad switch at the steering wheel- need to track voltage with a test light and see where it stops
01tl4tl's Avatar
If you did the work with battery connected it could have shorted out many things
Old Jul 17, 2010 | 04:01 PM
totaledTL's Avatar
Probably not the switch if it worked before you attempted repair- you did check the fuses, right?
Old Jul 17, 2010 | 07:31 PM
01tl4tl's Avatar
I was thinking of possible damage from Hot hitting Ground~
Not why it started having prob
Old Jul 18, 2010 | 08:50 PM
tl2001bot's Avatar
Brake light switch maybe? I don't know how it would go out when changing a bulb but its worth a shot. You should hear a click when the car is on and you lightly press on the brake pedal.
Old Jul 19, 2010 | 11:54 AM
TLer trash's Avatar
Check your fuses.
Old Oct 10, 2010 | 07:47 PM
dirtrider5070's Avatar
6th Gear
Still ahving this sma eproblem with my tl went through puddle and tail lmaps marker lights guage lights and meme seat went out, looking for tail light relay? anyone have any ideas?
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
brjones9
Sep 3, 2015 07:30 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
