Switchback help splice???
I have a '00 TL and bought the switchback LED from autoillumination. Problem is it's hyperblinking... Not sure which wires I needed to splice... Help pls
Did you buy resistors yet? I bought resistors from vleds and they worked great for me.
http://www.v-leds.com/BlinkerWarning...79822-1-2.html
I got those since I also had red rear led turn signals. They will also work if you only have leds in the front or rear instead of both so if you are deciding on whether to get rear led turn signals, then get those. If you want to save some money and are only going to do switchbacks, then get these http://www.v-leds.com/BlinkerWarning...83296-1-2.html
But anyways, the DIY is here https://acurazine.com/forums/showpos...00#post2074444 Props to "Josh" for the DIY and helping me out when I did this.
It was the splicer that wasn't working. I bought regular ones from Autozone and it worked well. Anyway if I decide to put LED for rear turn signals do I need to buy load equalizers for the rear? Or the front ones will sustain LEDs for the rear
pistacio
09-26-2015 09:45 AM
