Strange problem with headlight
Old Feb 18, 2007 | 05:05 PM
tonyk's Avatar
6th Gear
Here's a weird problem I've noticed recently. I turn on the headlights and they both work normally. If I flash the highbeam, the left headlight goes out. If I turn the headlights off and on again, they both work normally. I also noticed one night when I got home that the left headlight was out, but I don't remember if I used the highbeams on the way home (I live in the country). 2000 TL, 80,000 miles. Any suggestions as to what could be going on?
Tony
Old Feb 23, 2007 | 11:08 AM
Souped's Avatar
mine does that but only beacuse on eof my HIDs are out
Old Feb 23, 2007 | 11:40 AM
01tl4tl's Avatar
On your 2000- are the high beams a seperate bulb from the HID?
My 01 system leaves the lows on all the time and when you click highs on-
it adds those bulbs to the array so 4 lights are on.
This prevents your HID from electrical burst
You are about the right mileage and age for new bulbs
Phillips 4600K are recommended
Higher numbers like 5000 6000 8000 are
different color and put LESS light on the road
Stick to factory spec on this item
Replace in pairs
Old Feb 23, 2007 | 12:15 PM
fsttyms1's Avatar
Replace in pairs
2000 is the same set up as the 99 and 01.
Sounds like a short? or a bad bulb
Im still on my originals on my 2000 with 225k
Oh and stock is listed at 4300 If my aging memory serves me correctly
Old Feb 23, 2007 | 09:17 PM
tonyk's Avatar
6th Gear
Headlights and highbeams
The headlights and the highbeams are separate bulbs. I thought the problem might be due to a voltage spike on the lights circuit. Time for a new headlight bulb?
Old Feb 23, 2007 | 09:28 PM
01tl4tl's Avatar
You can swap the bulbs left to right and see if it goes away
Check all the electrical connections- spray cleaner in them and ck the ground wires are good
Spike could be problem- bulb? with it related to the hi beam- or just coincidence
Part #4300 not 4600 DOH! I am going to be placed on the no advice givin for a week list!
Better get it together before more mistakes!
TLrascal
Aug 3, 2018 11:00 PM
Robospinner
22
Sep 24, 2015 08:47 AM
MistaWet
Sep 15, 2015 08:26 PM
kareshi
Sep 3, 2015 03:38 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
