strange problem
Old Apr 1, 2007 | 03:54 PM
orgnlprankster7's Avatar
08 Civic SI
strange problem
hey my cars been throwing a code, saying that im running rich and an oxegen sensor is bad. the car hesitates while driving and sometimes jerks, but the thing i noticed more odd is when its idleing and im under the hood ill rev it...then it has a hard time getting back up to idle speed. almost like it is struggling to drive. i also have a gas smell coming from under the hood any ideas? it happend before and after i put in the spacerrs
Old Apr 1, 2007 | 04:00 PM
yessy_n_mike's Avatar
00-02
i have the same problem with mine. dont know what's going on
Old Apr 1, 2007 | 04:06 PM
08 Civic SI
i might just say fook it and change out the plugs, and air intake sensor. fyi its started happening when i first took off my intake manifold lastweek. i wiped off this nasty oily shit on my air intake sensor...prolly shouldnta done that. i also checked to see if i have a vacume leak, but i cant find one. any sings of a leak i should loook for?
Old Apr 1, 2007 | 04:08 PM
Tegmech's Avatar
Viaka Heaven
replace the 02 sensor. your smelling gas because it can't figure out how much fuel to put in. The getting back to idle speed thing isn't out of the ordinary with the 02 being bad either. Your probably getting horrible gas mileage too.
Old Apr 1, 2007 | 04:11 PM
08 Civic SI
yup like 7-8 mpg ok but i nee dto know, which o2 sensor do i repplace? the air intake sensor of the one behind the cat? will this also fix the issue of my car being really hesitant wile driving and jerking a bit at time?
Old Apr 1, 2007 | 04:42 PM
01tl4tl's Avatar
the O2 sensors send info about the air/fuel ratio inthe exhaust
With bad info you get bad running
Remove each one and inspect. One may have severe clogging of the slots or
otherwise appear bad.
There is an electrical test you can run if you have a multimeter
Buy the Bosch sensors at Autozone or place that will allow returns.
Try one sensor then the other. They are ~$85 each
There are also Denso brand for $65
Make sure to buy OE direct replacement NOT the ones you have to splice the wires
Not worth the trouble!
Old Apr 1, 2007 | 04:52 PM
08 Civic SI
wait so there is 2 o2 sensors and a air intake sensor? the guy at autozone said the air intae sensor was 32 bucks. where are the other o2 sensor located, easy to change? thx
Old Apr 1, 2007 | 06:40 PM
Tegmech's Avatar
Viaka Heaven
since i don't know much specifically about tl's yet, there are going to be somewhat close to the header (possibly 2 since its a 6cyl) but before the cat. There could be one behind the cat but i believe that one act as a stupid emmision control (someone correct me if im wrong but that was what it was for on a newer chrylsler sebring)
Old Apr 2, 2007 | 06:55 AM
08 Civic SI
well today on my way to work the car shut off at a stop light.. and every time i stop and hit the gas it seems likes its going to die unless i ease the gas veeery slowly. WTF im pissed now. i will have to get an o2 sensor, do i need to buy 2? could it possibley be the air intake sensor. PLEAAASE HELP
Old Apr 2, 2007 | 11:19 AM
Tegmech's Avatar
Viaka Heaven
Since it is just throwing an o2 code I would get one 02 sensor. If there are two, I wouldn't think both would be bad so try the first one and if it doesn't work then switch the other. I highly doubt the air intake sensor (map) would be causing the problem as serious as that.
I really need to get a helms for this car.
Old Apr 2, 2007 | 11:55 AM
NSXNEXT's Avatar
Ya know I had a similar problem when I was doing my TypeS intake manifold swap. Turns out I was an idiot and forgot to take the plastic wrapper off the cone filter (was trying to keep it from getting scratched up). Basically the car was being starved of air.
Maybe you've got an obstruction somewhere in the intake tract?
I've also had fuel leaks from the rubber washers that hold the fuel injectors in. Maybe you bumped one by accident when you were installing the spacers.
Stick your head under the hood while the engine is running and check for fuel dripping from one of the injectors.
Old Apr 2, 2007 | 12:40 PM
fsttyms1's Avatar
If your throwing a 02 code the code should say primary or 2ndary or front bank or rear bank. Id place money on it being a front one, since that reads before the cat. Also id stay away from mixing and matching 02s. some have had issues with them. Id stick with a oem 02.
Have teh codes read to see whats coming up.
And yes there are 2 02 sensors. the first one is on the exhaust right after the front and rear manifolds merge together and the other is by the cat
Old Apr 2, 2007 | 03:42 PM
08 Civic SI
strange i went back to autozone to pick up a sensor but ha dhim scan it again.he said there were 2 codes, the same and he couldnt ecifer them. only th dealer can. i think he said mac or somthing dunno. i ended up not getting one since i wanna be sure thats it
Old Apr 2, 2007 | 06:45 PM
01tl4tl's Avatar
OPster
Get the front O2 sensor and install it. Not a big project, may have to buy special socket to remove old one. Use anti seize on threads just like spark plugs.
Autozone has no hassle return policy
Open hood and look as directed in above post
CODES are not diagnosis- they are clues to the real problem
SidhuSaaB
May 30, 2020 12:40 AM
mlody
Dec 4, 2019 02:11 PM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
