Strange noise under hood. Need help
Old May 25, 2012 | 04:03 PM
marso's Avatar
Hello everyone, my name is Mark I just bought an 02 TL-S with 62k original miles. The thing is mint but I am having a weird noise that sounds like a low pitched Kazoo or duck call coming from under the hood. It only happens when you start the car cold then when you take off it "buzz's" for a second then a brief pause as you're accelerating then another one second "buzz" then it doesn't do it again until the engine is stopped, restarted and then go through the same routine. I don't know if it is an actuator or a buzzing PCV but it does it the exact same way evertime.
I also get a deep drumming noise coming from the plastic air intake at idle.
Has anyone had this problem and how is it fixed?
Old May 25, 2012 | 05:41 PM
JDTL-S2002's Avatar
Is the intake stock or aftermarket?
if aftermarket disconnect the vacuum lines running to it and see if humming subsides.
if stock take it off and make sure its not cracked
Old May 25, 2012 | 08:05 PM
01tl4tl's Avatar
register with www.owners.acura.com and download the free owner book
I think you are hearing the ABS self test at 5 and 15mph
also register with acura care 1 800 382 2238 x5
tell them new owner and ask if all recalls are taken care of
Welcome to the ziner nut club!
Old May 26, 2012 | 11:05 AM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
01tl4tl nailed it on the ABS self-test. Every new owner (I did too) asks about that noise - perfectly fine. Regarding the droning, they may have removed the intake resonator, which quiets things a bit when it is still installed. Many people remove those for better throttle response. Again, it's fine, but takes some getting used to, and you can forget about sneaking up on anyone.
Old May 26, 2012 | 03:19 PM
marso's Avatar
Thanks for answer that's pretty much the speeds I hear it. Any way to silence it? I can't believe a manufacturer would have something make a noise like that intentionally. I'ts irritating as hell.
Old May 26, 2012 | 05:01 PM
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
Every TL is like that, just try to ignore it - eventually you will.
Its just doing its job.
Old May 27, 2012 | 10:51 AM
01tl4tl's Avatar
how loud is it? Is this your first abs car?
You want the ABS working- just in case of that `stomp and steer braking manuever`
a certain spouse may need to do--when traffic or accident is suddenly right in front of them
abs allows you max application of the brakes,, without skidding,, and having no braking~
Old May 27, 2012 | 02:22 PM
marso's Avatar
It's not my first ABS car but it is the first one that ever made the noise. I don't know what a "normal" loudness is but it is very noticeable every time. I don't want to disconnect the ABS just wanted to know if I can quiet the noise.
Old May 27, 2012 | 06:26 PM
01tl4tl's Avatar
pull the abs fuse/relay and drive slowly up the street
20mph without abs --you should be ok~
a light thunk as the pump or whatever does its thing is normal
radio off, drivers notice--but after reading owner book - understand whats going on
= the car has to run a few systems test,,,
wont hurt to go thru the brake system, lube all moving parts, flush out decade old fluid,
restore proper braking!
Old May 27, 2012 | 06:28 PM
01tl4tl's Avatar
look in Regions link,,
meet ziners in your area and test drive another car,,have someone ride with you,,
oh thats normal or uh-oh thats not normal!!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
