Stock alarm don't beep
1 Post
Need help on my stock alarm I just replaced the buzzer that goes behinde the rite front fender bcuz when I would lock my car and click it twice it wouldn't beep and now that I replaced that buzzer it still don't beep? What's wrong with it?
I Already told ya, You need to check your hood sensor or trunk sensor. A better way to do so is with the ODO itself.
Your ODO will put a little car in it and if you open a door it will show up so it will the trunk, So if any sensor has gone south it will always be On on your ODO. If anything looks okay Check your Hood Sensor.
Thats why you dont get the beeps, The beep itself is telling you that everything is OK.
Another feature that tells you so are the Parking Lights On/Off, If your parking lights turn On and Off just 2 times everything is OK in the System. If they dont turn ON/OFF 2 times something is wrong...
!!!!I ALREADY POSTED THIS ON ANOTHER THREAD!!!! THIS IS A RE-POST!
Ill put this in High Quality BMP for Image Clearness! (56K WARNED).
So please bear the Little Download of 3MB.
INFO ABOUT KEYLESS OEM ALARM ITEMS:
"If one of the Switches is misadjusted or there is a short in the system, The System will not Arm. As long as the Control unit continues to recieve ground signal, it senses that the vehicle is not closed and locked, and it Will not Arm."
INFO ON HOOD SWITCH TEST:
Thats All! L8ters and Hope its Usefull....
rockyboy
12-06-2022 02:29 PM
rockyboy
01-25-2016 06:00 PM
sockr1
10-01-2015 01:31 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
