Funny Suspension Noises
Old May 16, 2011 | 10:06 PM
iamloyal35's Avatar
7th Gear
Just changed my Springs and Struts and also my top strut mounts on front and rear of my my TL Type- S and im still getting this nasty thud sound. Anyone have a clue on what it can possibly be?
Old May 17, 2011 | 01:37 AM
01tl4tl's Avatar
were you getting the noise before this install? ck the sway bar end links and all the suspension and steering parts-bushings
if new noise- are the front and rear springs on the correct ends of the car- they have been install wrong before~
new noise: are the top nuts that hold the sping and shock together tight to spec
How exactly did you tighten them? air gun?
Old May 17, 2011 | 08:51 AM
iamloyal35's Avatar
7th Gear
To Behonest I didn't think that Specs had to be considered because of did this kind of job on all of my cars and never ran into a problem like this.. and yes it was making the noise prior to me changing the spring and strut. However I will look into the sway bar links from the front right and left, i don't know why i never thought of that. Do you know where I can get those tightening specs for the Struts?
Old May 17, 2011 | 11:00 AM
01tl4tl's Avatar
dont know the exact spec--always did it with an air gun --blasted on is good!!
I was just making sure you didnt tighten with a hand ratchet and think it was tight = leading to thumping
Moog brand end links are way better and easier to install the stock units
Old May 17, 2011 | 02:33 PM
iamloyal35's Avatar
7th Gear
o ok yeah i did it with a Gun.. and ok ill letchu u kno the results after installment. once again greatly appreciated.. if u have or can think of some other reasons that can cause it to make the noises just let me know.
Old May 17, 2011 | 07:18 PM
01tl4tl's Avatar
you are in the right section- problems and fixes..scroll thru old postings for more help
Ck the diy list- iirc there is a noises section there
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
Old May 20, 2011 | 08:04 PM
iamloyal35's Avatar
7th Gear
changed the sway bar links... light improvement made but i still have a nasty knock... but i did discover that i need to change my right wheel bearing in which im going to do soon.. so hopefully eliminates some of the sounds
Old May 20, 2011 | 09:18 PM
sbuswell's Avatar
I need 2 more gears
check your lower ball joints too.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
