still having ac problems
Old Jun 27, 2012 | 04:53 PM
jo3lo22's Avatar
Unhappy still having ac problems
so i have been trying for the last 3 weeks tryna fix my ac ....when i turn on the ac no cold air blows nor does the ac clutch engage...i did the self diagnostics and it said the mix motor was bad..after opening it nothing was bad ..then i did a self diagnostic and got no code ....so then i replaced my pressure switch and tada! nothing!...i jumped the pressure switch plug and everything starts up..so now my question is can it be that the pressure switch is doin its job of not letting the compressor work cause of low frion? or can the drier be bad?...i just want my ac again!
Old Jun 27, 2012 | 08:55 PM
Skirmich's Avatar
This may be more complicated that it seems with no Code...
Why dont you go to a honda dealer to get a diagnose?
Dont go to Acura they seems to Ask for More than its Needed (Money Wise)
Old Jun 27, 2012 | 10:41 PM
jo3lo22's Avatar
Im goin to check my frion levels if its ok ..to honda we go
Old Jun 30, 2012 | 03:45 PM
YeuEmMaiMai's Avatar
is there refrigerant in the system? Compressor will not cycle if the low pressure switch cuts it out. Proper refrigerant is r134a
Old Jul 1, 2012 | 12:35 AM
jo3lo22's Avatar
I put a guage in it n marked that it had nothing...my theory is when my condenser fan was bad i turned on my ac ..when i drove my car cold air came out the vents..and when i got cought in the rain i put the temp to 60...so im guissing it threw the frion out and emptied it
Old Jul 1, 2012 | 04:17 PM
05_NBP_TL's Avatar
HE>i
whats AC?
have not had cold ac in my 99 TL for some time now. not going to put the money into it to fix it either it is truly a beater car for me.
it gets cool, but i could run it for 30 minutes wide open and it never gets too cold in the car. done the recharge kit and it helped some, but nothing significant. im better off rolling the windows down when possible. LOL
hope you get yours fixed OP.
Last edited by 05_NBP_TL; Jul 1, 2012 at 04:18 PM. Reason: bacon, lettuce, tomatoe
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
