Steering wheel vibration
Old Jan 6, 2007 | 12:30 AM
merkin110's Avatar
Ever since i bought my car i have had a slight vibration at all speeds. I have already replaced all four rotors, pads, new wheels (18" RJ Inspyres), wheel balance, rotation, and wheel alignment. Anybody have any ideas? This is really annoying. All help and suggestions would be much appreciated
Old Jan 7, 2007 | 12:46 AM
MBP_TL's Avatar
6MT NBP UA7
possibility it may be a ball joint.
Old Jan 7, 2007 | 09:22 PM
merkin110's Avatar
Could i check the ball joint or would i have to take it down to a mechanic.
Old Jan 7, 2007 | 10:03 PM
MBP_TL's Avatar
6MT NBP UA7
I would jack one side of the car up in the front until the wheel is off the ground,then try to shake the wheel left to right and up and down and if there is any play in there then it's probably a bad ball joint. Anyone that does an alignment can tell you right away whether or not you have a bad ball joint.
Old Jan 8, 2007 | 01:19 PM
merkin110's Avatar
Isnt that the way you check your wheel bearings?
Old Jan 8, 2007 | 04:10 PM
lostkhan's Avatar
I have Changed my Ball joints because they were makin ugly sounds like 2 months before But not because of that problem. Today i have the same wheel vibration problem like you have since i replaced my rear wheels and put them in the front and viseversa. That way my Allignment was Good but this slight steering wheel vibration started.
Old Jan 9, 2007 | 11:29 AM
lostkhan's Avatar
Any UPdate on this?
Old Jan 9, 2007 | 08:29 PM
MBP_TL's Avatar
6MT NBP UA7
try looking into the suspension components as well, for example the upper/lower control arm,rear control arm,tie rods and steering racks maybe even some of the bushings etc... best thing to do in my opinion would be to take the car on a lift and inspect the undercarriage for any suspicious or wobbly parts but that just a suggestion. not sure if the car has seen some major potholes/accidents/curbs but that will all cause some damage to the vehicle itself
Old Jan 9, 2007 | 09:55 PM
fsttyms1's Avatar
possible bad halfshaft would be my guess. I would have all teh suspension inspected to make sure nothing is loose, if not and all balljoints are good, id suspect a bad halfshaft (especially if it does it with 2 different set of rims and tires)
Is there any noise to the vibration or just a shaking?
Old Jan 9, 2007 | 10:26 PM
merkin110's Avatar
no noise at all.
Old Jan 10, 2007 | 09:28 AM
fsttyms1's Avatar
then im leaning towards a bad halfshaft
Old Jan 10, 2007 | 12:11 PM
merkin110's Avatar
So should i take it down to a local mechanic or a tire/suspension place like Les Schwab? Also any idea on how much it would cost to replace this item?
Old Jan 10, 2007 | 05:00 PM
fsttyms1's Avatar
If you ant figure it out id suggest a shop that could. What that would be in your area???
Old Jan 12, 2007 | 05:21 PM
civic2000's Avatar
Could this be the reason why my my steering wheels shakes @ 50-60mph and when I break 20-30mph? I'll have to jack the car up this weekend and shake the sh!@$% out of it.
120 miles on new tranny and counting!
Old Jan 17, 2007 | 10:16 AM
NHBTL-S's Avatar
I was told my lower ball joints needed to be replaced. My alignment never really straightens out and won't because of this. (I've had 3 alignments done) And my steering wheel vibrates and higher speeds. Also accompanied is a noise that is heard at the same speed as the wheel is turning. I hope after I change out my lower ball joints and replace my 4 tires and give it another alignment that it's okay.
Old Jan 18, 2007 | 07:59 PM
SSMTL01's Avatar
https://acurazine.com/forums/showthread.php?t=149691
ya might want to read through this thread as well
Old Jan 20, 2007 | 10:57 PM
Clean AC's Avatar
I had the same problem @ 40 MPH and then came under acceleration. Found out that it was my innerjoints on the drive shaft (from Acura). Replaced both left and right front axle dirve shafts and it cured the problem. I had my stock rims then switched up to 18" s. After time just wore out the axles, my advice get your axles checked out!
Old Jan 22, 2007 | 11:24 AM
sb65's Avatar
When I bought my certified used '03 TL, I had steering will shake at 70 - 75 mph. It took 2 trips to the dealer, but they finally determined that one of the rims was slightly bent and replaced it to fix the problem.
The steering wheel shake when braking, only between 20 and 30 mph sounds like warped roters to me. I have the same thing, but will wait to either turn 'em or replace them since it isn't that big of a deal. My 1994 Accord was the same way -- seemed to warp pretty easily/regularly.
Old Jan 22, 2007 | 09:31 PM
merkin110's Avatar
Just took my car into a shop and i have a slight bend on one of my wheels. I hope that is the only issue.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
04tler
Sep 10, 2015 04:03 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
