Steering pull
Old Aug 9, 2011 | 04:27 AM
Black Tire's Avatar
99 TL, 06 E350
Steering pull
My car is pulling to the right. I had an alignment done just 3 months ago and I have been careful driving the car ever since. I may have gone over some rough roads, but was careful.
Could it be something that is worn like a tie rod, stabilizer bar or suspension piece that is worn?
Old Aug 9, 2011 | 09:56 AM
01tl4tl's Avatar
totally possible and something a good align shop cks for you- but many dont- they just set to spec and hope you come back for repairs at inflated prices
have a different shop give a diagnostic for problem of -wont hold align
control arm bushings are a popular failure, tie rod ends directly affect steering
is your car lowered? wears out those parts faster
even one good pothole or curb kiss can throw the alignment off
Old Aug 9, 2011 | 11:15 AM
swoosh's Avatar
takin care of Business in
1> check your tire pressure....if once side is low it can result in a pull...
2> recheck your alignment...sometimes a small pothole results in a misalignment....its how u hit it and not how big it is....
3> do what 01tl4tl said....
Old Aug 9, 2011 | 11:17 AM
Black Tire's Avatar
99 TL, 06 E350
Originally Posted by 01tl4tl
control arm bushings are a popular failure, tie rod ends directly affect steering is your car lowered? wears out those parts faster
Yes my car is lowered a bit with H&R Sport Springs. Could I just go to dealer and ask to check these parts without an alignment?
Old Aug 9, 2011 | 01:01 PM
01tl4tl's Avatar
eff the dealer on this,,on most repairs actually,,nothing agaisnt the techs there, just how it all works and how much you get charged
(former insider turned whistleblower)
a real alignment shop,,not big name tire stores with a rack and corporate quotas...
that your car may be used to meet...,, look in phone book for a shop that specializes in this!
They will put in on the lift and inspect all the steering parts- control arms- bushings etc
and find the problem-- if its parts related..for free or minimal charge
dealer gets 1.5 hour diagnosis fee !!
but I'm with swoosh on this, ck the tire pressures
Guess who recently had a nail in the RF,,car had been pulling, mileage down,,
along with the air pressure from its normal 40 to 28
Im claiming ~its the wifes car~ she drives it way more than me,,but give her credit for seeing low tire pressure on 40 profile tires! they always look low!!
Old Aug 9, 2011 | 01:25 PM
swoosh's Avatar
you bet LOL...my girl rolls in a 40 profile tire and i always pull the tire gauge and it always smiles in my face with a 35psi LOL...
Old Aug 9, 2011 | 01:49 PM
TLer trash's Avatar
Try swapping the front tires side to side. If the car now pulls left or goes straight, you have a tire problem. I'd still get the front end and alignment checked.
Old Aug 15, 2011 | 03:49 PM
Black Tire's Avatar
99 TL, 06 E350
I took the car to an alignment specialist. They fixed the steering pull. They found nothing wrong with any of the tie rods and such. Since my car was lowered a bit they found my camber off a bit. They recommended I get a camber kit for to fix that. Does anyone know where to get them for cheap?
Old Aug 15, 2011 | 04:59 PM
fsttyms1's Avatar
I really wouldnt worry about camber. Especially if you are slightly lowered and its only off a bit. Just rotate your tires regularly and you will be fine.
Old Aug 15, 2011 | 05:08 PM
Flipster23's Avatar
I wouldn't get a camber get on such a mild drop.. but Ingalls are good if you really want a camber kit
Old Aug 15, 2011 | 08:02 PM
01tl4tl's Avatar
if negative camber is less that 1.5 degrees you are fine !! Im neg 1.1 and 1.4 on mine
only if its pushing `neg 2 degree` will it cause major tire wear and kits are a good idea
in reality, It `turns in better to the corner` with that little extra negative camber = angle of tire to road
stock specs is 0 with a 1 degree limit
Old Aug 19, 2011 | 10:25 AM
Black Tire's Avatar
99 TL, 06 E350
Yes the mechanic showed me the numbers on the machine. One side was like 1.1 the other 1.4.
I agree about turning into corners.
Old Aug 19, 2011 | 10:50 AM
01tl4tl's Avatar
thats fine for negative camber--based on being the same as my car!
watch the front tire wear on the edges to know if anything is really wrong
shops always try to sell the camber kits, its a money maker
they know the spec allows from zero to neg 1,,a tick past that isnt reason to replace anything--you know its lowered and thats why its gone neg
If it were stock height and neg camber = you hit something!
Old Aug 23, 2011 | 11:46 AM
TLer trash's Avatar
While those camber numbers shouldn't cause excessive tire wear, they might cause a pull. Since you know the front end is in good shape, I'd be even more prone to swap the front tires side to side just to rule them out.
Old Aug 25, 2011 | 08:18 AM
Black Tire's Avatar
99 TL, 06 E350
I just put back my all season tires on my car for the coming change in weather. The car goes straight as an arrow. Those guys did a really good job:
If anyone in the GTA east end area needs a good alignment shop, this is where I went:
http://www.limitlessauto.com/
Old Aug 25, 2011 | 02:31 PM
TLer trash's Avatar
Did it go straight after the alignment, or did swapping the tires do it?
Old Aug 26, 2011 | 12:47 PM
Black Tire's Avatar
99 TL, 06 E350
I had low profile tires on 18inch wheels. They tracked the road surface so there was slight wandering. When going back to the my stock all season tires/rims. The car runs almost perfectly straight even on uneven pavement.
Old Aug 27, 2011 | 10:41 AM
Diva 4 Life's Avatar
99Ackrite
It seems almost all low profile wider tires tend to cause a wondering issue or pull. Gotaa love it.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
Euro4gen
Dec 12, 2015 03:14 AM
