Starting Problems on Busy Day
Old Nov 1, 2006 | 10:53 PM
solvibe's Avatar
Car has 83,000 miles on it.
On my busy days, when I have to start and stop allot, when I have to start it again it will start and then stall right away, have had this problem before.
The only way get the car to go is to keep the engine revved up around 2 or 3 rpms while keeping my foot lightly on the break and putting it into drive (allot of times parallel parked so got to do this in reverse and drive until out of spot and on the go), then letting go of the break to go, after the car gets going it will stay level until I start & stop again.
What could this be?
Can't help but think its the same problem as before, when I brought it to the Acura dealership months ago and took them a week to try to find out what was wrong, which they never really did find out I think?
What they did do is replace injectors & regulators. And said would need new ECU
Old Nov 2, 2006 | 07:44 AM
Bob_F's Avatar
Definitely search the forum for "stall" and you'll find a ton of threads.
But here are a couple of quick thoughts.
Is the dash immobilizer key symbol flashing when the car won't start?
If so, you might have a problem with your key or the ignition switch.
Have you tried another key?
Do you have a second Honda or Acura key on your keychain? If so, and if it is an immobilizer type, that can cause your car to stall. I actually had a stalling problem with my 1999 TL that was due to a Honda key on my keychain.
Have you ever had your Idle Air Control Valve (IACV) cleaned? These can stick and cause low RPM stalls.
Good Luck!
Bob
Old Nov 2, 2006 | 07:47 AM
Bob_F's Avatar
Also, have you checked or replaced your engine air filter recently?
Bob
Old Nov 2, 2006 | 06:49 PM
bkzjimmy's Avatar
NiGhT rIdEr
What could this be?
i have the same problem, but i noticed it only happens during the winter or when its a lil cold outside. i remember having to keep it revved or put it in drive and pull out quick or sometimes i would just let the rpms jump till it stopped shaking on its own. its kind of annoying when im in a rush.
btw....sometimes when i kept my foot on the gas to keep the rpms up the CEL light would come on.
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
