start up problem...
Old Feb 4, 2008 | 09:20 PM
kingofkwenz's Avatar
start up problem...
i got a 99 TL..when i start the car in the morning its all good..but after it warms up later on i try again turning it on and it starts to wanna turn off and i have to keep it accelirated for a sec or two then finally it goes back to normal..i've got a new battery..could it maybe be cuz off my egr not cleaned or cuz of my cataylic that need to be replaced?? there both on my check engine codes..any idea guys...need help!
Old Feb 7, 2008 | 12:32 PM
any help guys..??
Old Feb 7, 2008 | 12:43 PM
Bob_F's Avatar
So are you actually getting check engine codes on the catalytic converter and the EGR? If so, that where i would start.
And, since you have a 1999 TL, was the ignition switch ever replaced under the recall? If not, you might as well have that done to eliminate it as a possibility.
Another common issue is a sticky idle Air Control Valve (IACV) although I'm not sure if that could explain why the problem occurs when the car is warm.
Also, try a forum search for start up and stalling problems. There are a ton of threads on this.
Old Feb 7, 2008 | 07:51 PM
cool bro..thanks
Old Feb 9, 2008 | 01:35 PM
could it maybe be my spark plugs..? havent changed them since i bought the car like a month ago..n i dont know how long ago the previous owner changed them..
Old Feb 9, 2008 | 02:17 PM
01tl4tl's Avatar
remove a spark plug and see what it looks like. It may be original
Old Feb 21, 2008 | 02:51 PM
i changed it but it still has the same problem..
Old Feb 21, 2008 | 03:13 PM
Bob_F's Avatar
Do you mean that you changed all six spark plugs? Or did you mean the ignition switch?
Old Feb 22, 2008 | 04:00 PM
chckn's Avatar
I think that I have the same problem.
Only happens when the car is warm... don't know why...
When I start the car, it idles REALLY low, then will shut off if I don't step on the gas to keep the RPM above 1k or 2k. After I get the car going, it's fine again.
Old Feb 22, 2008 | 08:15 PM
i changed the spark plugs. n ima be going monday to get my ignition switch changed..
but do u think it could be the ignition switch?
Old Feb 22, 2008 | 08:45 PM
01tl4tl's Avatar
did you install NGK Iridium IX, or some crazy 2 dollar spark plug that wont work in the TL?
Old Feb 23, 2008 | 02:49 PM
no i bought the 8 dollar ones..any ideas?
Old Feb 23, 2008 | 03:10 PM
Bob_F's Avatar
I do think that it could be the ignition switch, especially if it was never replaced under the recall.
My 1999 TL had the original ignition switch replaced under the recall. Then, about a year ago, that replacement started to fail. In my case the symptoms were difficult starts, stalling at low RPM and occasional "power outages" while driving. All of this odd behavior was corrected by replacing the ignition switch.
Old Feb 24, 2008 | 05:36 PM
^ cool well i'll let u guys know if it changes..
Old Feb 26, 2008 | 09:26 PM
yup it was the ignition..thanks guys..hopefully it wont fuck up again..
Old Feb 26, 2008 | 10:35 PM
01tl4tl's Avatar
good deal- still under warranty for the switch?
Old Feb 26, 2008 | 10:52 PM
Bob_F's Avatar
Great news! Thanks for the update.
Old Feb 28, 2008 | 01:07 PM
woffordbear's Avatar
Another start up problem
2003 TL. Car would not start, and was essentially dead with no electrical power. Jumped off the battery, got it started, and had battery replaced (it needed to be replaced anyway). Worked fine for about a week, and then it would not start again, but did start after a few minutes. Had corroded battery cables replaced.
Now, a few weeks later, having problems starting again.....everything electrical is dead, but after a few minutes, the car starts and everything works fine. Now, sometimes the car starts just fine, and sometimes it doesn't.
Any suggestions out there.
Old Feb 28, 2008 | 02:24 PM
phee's Avatar
I got the Shifts
start your car and push you key inward after cranking. if that keeps the car on you need to replace your iggy switch too
Old Mar 2, 2008 | 11:00 AM
Soo ICeY's Avatar
guyz im havein a problem.......my car wont idle at 750rpm....it goes up to 2000rpm..then after a while it starts going up and down form 1500rpm to 2500rpm...i donno what going on with this..and all my lights turn on the engine light VSA, and the triangle thini???any suggestions??
Old Mar 3, 2008 | 03:34 PM
Luke7's Avatar
WNC Real Estate Sales99TL
https://acurazine.com/forums/showthr...ght=rough+idle
https://acurazine.com/forums/showthr...ght=IACV+clean
Old Mar 3, 2008 | 03:35 PM
Luke7's Avatar
Sometimes you just have to replace it if cleaning does not help. I have replaced them on my Prelude and Honda Accord.
Old Mar 3, 2008 | 09:44 PM
came back today.my idle dropped for a sec until i kept my foot on the acce. wat could it possibly be.?
Old Mar 27, 2008 | 07:09 PM
hAadOokEn's Avatar
'99 TL Start up problem also
hey guys.. i've been reading and searching about start up problems when my car didnt start up today.. '99 TL with 151k miles..
started when I forgot to turn off my aftermarket foglights for about 8-9 hours last night.. so the battery drained like hell.. tried to start it but no go heard the click though trying to turn on the engine.. so i had warranty on the battery so i got a new one.. put it on.. reset everything.. tried turning it on.. nothing.. no click just the assesories everything worked..
i havent changed the spark plugs for 4 years.. dont know if the previous owner did when i bought the car @ 98k miles.. so should i buy new ones? you guys said something about the spark coils?? should i change those also or buy one and test all six to see which is out? I didnt even know about a ignition switch recall.. should i buy that? Which would be my best bet?
any help or suggestions would be great guys.. Thanks
Old Mar 28, 2008 | 04:46 PM
hAadOokEn's Avatar
anyone know if there are only 2 bolts for the starter or 3? I think my starter went bad.
Old Mar 28, 2008 | 07:11 PM
hAadOokEn's Avatar
help anyone? anyone know if we have a killswitch and if that can be the cause of it not starting?? please my car is on jacks
rockyboy
Aug 4, 2024 10:35 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
jordanboi
Sep 5, 2015 01:33 AM
