Stange sound....only when starting to drive
Old May 21, 2008 | 03:19 PM
jazzman_q's Avatar
I have noticed a strange sound when I initially start my car and it has been sitting ofr a while (say overnight, or when leaving work), and start driving there is this little "bbbrrrppp" sound that I get twice when starting out, then I don't hear it again utill the next time I start up and drive off. I was thinking Torque converter, but that is more of an "wild ass guess" than a rational information based decision.
No other problems.
I have about 87K on it
Has anyone else had or heard of this before?
Thanks in advance.
Old May 21, 2008 | 03:27 PM
jazzman_q's Avatar
Edit: No CEL of any sort on dash, I will hook up to scanner in the morning, and check for codes.
Old May 22, 2008 | 04:56 PM
jazzman_q's Avatar
Anyone out there with info?
Old May 22, 2008 | 06:49 PM
fsttyms1's Avatar
Its completely normal and you should hear it. Its the ABS self test/prime. You should hear it at start up and at 15mph.
Old May 22, 2008 | 07:13 PM
01tl4tl's Avatar
I thought the 2nd abs self test was at 5 mph, but I defer to our guru on this specific
Changed the brake fluid lately? then its time!
once a year after year 3 of cars life!!
Old May 22, 2008 | 08:31 PM
fsttyms1's Avatar
It may have been. Its been so long since i typed it and actually heard it since i no longer have it i dont remember
Old May 22, 2008 | 09:26 PM
jazzman_q's Avatar
ABS Prime/Test...oh ok, was not sure.
None of my other vehicles with ABS do this, that I can tell, but ok.
Yes is does happen when starting out say 3-5 mph and again around 15, so I can relax a bit.
Thanks a bunch, that definately had me worried.
Old May 22, 2008 | 09:52 PM
02type-s's Avatar
-Arsenic-
Why no abs? Are all the 6spd converions like that??
Old May 22, 2008 | 11:32 PM
01tl4tl's Avatar
jazz
here is the owner manual free download- it will tell you all about the abs and traction systems- good stuff to know
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
click your year then model
Old May 22, 2008 | 11:34 PM
01tl4tl's Avatar
other cars with ABS have different ways - but they all self test on startup-
I recall that bmw had a flashing triangle light on dash on starting - then you tap the brakes- it does its test and the light stops- then ok to drive
Old May 27, 2008 | 07:34 AM
fsttyms1's Avatar
Because the TL has TCS/ABS built into one module. The 6 speed does not have TCS. The connections are different in the wire harness. I could have gotten it to work im sure, but i dont mind not having it.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
jordanboi
Sep 5, 2015 01:33 AM
