srs warning - 2003 TL Type S, non navi
Old Nov 27, 2006 | 05:12 PM
cubalibre1971's Avatar
Cubalibre
Unhappy srs warning - 2003 TL Type S, non navi
Help!!!! I somehow tripped the SRS warning light and it is now on constantly. Two things may have led to this. I removed the back seat in eforts to get the stock sub amp to work with an aftermarket hu. No luck, put everything back. I did accidentally remove a belt bolt from the back seat. I also accidentally blew the reverse lights fuse when installing the rear view camera that came with the radio. The only wires I have cut into are the sub amp's. I have checked all interior fuses on both sides of the dash. Is there some way to reset the light without going to the dealer?
Old Nov 27, 2006 | 05:17 PM
SteveP66's Avatar
Kaa - Ching !!!
From: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
If you are still under warrenty you can just tell the dealer it came on by itself...........don't go telling them more than you need to
Old Nov 27, 2006 | 05:25 PM
fsttyms1's Avatar
Here is a link on how to reset it yourself
http://www.geocities.com/myintegra96/srs.html
Old Nov 27, 2006 | 05:52 PM
Trackruner228's Avatar
When mine was on it had something to do with with the passanger seatbelt buckle which apparently has a lifetime warranty.
Old Nov 27, 2006 | 06:04 PM
superfob's Avatar
Just had my seatbelt buckle replaced as well because of the SRS light.
Old Nov 27, 2006 | 09:29 PM
Cubalibre
Thanks. Any idea where the MES connector is on the TL? Lots of yellow and green connectors that might be it.
Old Nov 27, 2006 | 09:38 PM
Cubalibre
found it
Thanks all. I found a service bulletin. Here it is for anyone else in this mess.
/tsb/TSX/b02-020.pdf
Old Nov 28, 2006 | 10:05 AM
fsttyms1's Avatar
yea, its in the same spot as in the pic. Back of the drivers side fues panel. 2 wire conector
Old Nov 28, 2006 | 09:56 PM
Cubalibre
Yes!!!!
Thanks for the info all. Just tried the fix and got it on the second try. I was really dreading going to the dealer even though it wouldhave probably been a non-issue. Thanks again!
Old Nov 29, 2006 | 11:29 AM
fsttyms1's Avatar
Glad we could help. If it does com back on bring it to the dealer. That means something is wrong. If that light is on, None of the airbags will work in the event of a accident, and if your in a 02-03 your seat belt pretensioners wont work either
LECKEY73
Feb 22, 2016 01:32 PM
mugen_kid
Nov 13, 2015 10:38 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Ny1718
Sep 11, 2015 09:21 AM
