SRI problem w/ 99TL HELP!
Old Sep 29, 2005 | 04:08 PM
99TL_acula's Avatar
Hi,
I installed the SRI last night, and while I was installing it, i noticed there's a small radiator like thing inside my stock airbox and filled with coolant. I unhooked the 2 pipes that were connected to it and managed to let the coolant circult back to throttle body area (the 2 pipes that were connecting the radiator thing were coming out underneth the throttle body). I would like to know if im doing the right thing or i need to hook up that radiator thing? Right now i do smell some chemical kinda stuff coming out the engine bay, and I'm having a hard time starting up the motor. Some suggestions please!!!!! Thanks
Old Sep 29, 2005 | 04:51 PM
MikePA's Avatar
Re-routing the coolant hose is the right thing to do. The stock air box, including the mini-radiator, gets removed.
I have a '99 and installed a Comptech Icebox. The only place coolant could be coming from is one of the places underneath the TB. Are you sure there's not some kind of blockage in the intake path somewhere? I imagine that could cause hard starting.
Old Sep 29, 2005 | 05:11 PM
MikePA's Avatar
Just thought of this, and I'm not busting on you, if the filter that came with your CAI had a clear plastic wrapping (like Saran Wrap) around it, did you remember to remove it?
Old Sep 29, 2005 | 06:07 PM
99TL_acula's Avatar
Thanks for clearifying my concern about the mini-radiator, and yes i did remove the wrapping. Is there anyother reason that can cause my car having hard time starting?
Old Sep 29, 2005 | 06:51 PM
ou sig's Avatar
Boomer SOONER
not really, just make sure all your hoses are connected properly and your vacuum hoses are on the intake and you should be fine there - now it could be a battery problem or something like that...
Old Sep 29, 2005 | 07:38 PM
MikePA's Avatar
I agree with ou sig. There are 2 hoses that get removed from the OEM intake that have to be re-attached to the CAI.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
