Squealing noise in reverse
have you checked the brake pads for the rear,,and front,, because sounds travel in the car
could be dust buildup in the park brakes- inside the rear rotors
note on aftermarket rear pads
Some have an extra tab on the backing plate-
if present it hits the caliper piston first and makes the pad extend crooked-
result is only half the pad contacts the rotor!!
the correct pads have a tab at one end for the noise maker arm, and may have another at opposite end that does nothing
the wrong pads have another raised tab/peg in the top center of inner pads backing plate
easy way to tell after they are installed is ck the inner side of rear rotor for wear
If rusty on half its width and shiny other half--guess what!
You can grind that tab off and reuse pads if angled wear not severe, it will even back out
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
