Spungy Brake?
Old Nov 28, 2009 | 01:01 PM
mirage47's Avatar
Spungy Brake?
Hello. 2000 TL. Needed brakes and the rotors were a little warped and the pedal was spongy, to me (I have an 05 TL). I replaced the rotors and pads with Napa stuff and bled the system and the pedal is still spungy. When depressed, the pedal goes down at least an inch and a half and does not feel solid like my 05. Is this normal or does it sound like a weak master cylinder? Anyone else have this issue? Thanks for the tips!!!
Old Nov 28, 2009 | 03:31 PM
gold2003tl (90)'s Avatar
2003 TL-p
try bleeding it out again. what method of bleeding did you use? what kind of Napa stuff did you get?
Old Nov 28, 2009 | 03:39 PM
mirage47's Avatar
Thanks gold. I got the NAPA premium rotors and Adaptive One ceramic pads. Bleeding was with wife pumping the pedal (pump and hold) and me bleeding starting at right rear, then left rear, then right front then left front. Used DOT 4 fluid. Sucked out the fluid in the master before filling and bleeding.
Any other bleeding techniques better? Thanks again!
Old Nov 28, 2009 | 04:45 PM
spiro's Avatar
LF RF RR LR is what Honda says.
Old Nov 28, 2009 | 07:15 PM
spoka's Avatar
yep sounds like you have air in the system, rebleed and try again
Old Nov 29, 2009 | 09:38 AM
mirage47's Avatar
Thanks all!!! Rebled using correct sequence, and brakes are now solid. Thanks again, great info here.
Driver heated seat issue is next.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
