Shifter assembly lights out and cigarette lighter.
Old Feb 10, 2015 | 10:34 AM
Rjw6453's Avatar
4th Gear
Cigaretteighter under neath radio and the shifter lights are not working. Haven't got my Haynes in yet to figure it out. And in Manual and fuse box diagrams I can't find anything. Everything else works though. Thanks for any help.
Old Feb 10, 2015 | 10:36 AM
Rjw6453's Avatar
4th Gear
Sorry for noob post. Car is a 2000 TL automatic.
Old Feb 10, 2015 | 11:44 AM
01tl4tl's Avatar
grab the 12volt test light and start cking fuses
may not have exact function you need listed on cover- have to test all
01tl4tl's Avatar
do any work on the car at all- recently- before this happened?
Old Feb 10, 2015 | 03:34 PM
Rjw6453's Avatar
4th Gear
I just bought it a week ago. Radiator. Sway bar end link. Tires balanced and a good detailing. It's did this from day one. It's weird the accessory power outlet works behind the shifter in the rear center console. And all radio works. Seems all cars I've had before share radio and cigarette lighter on a fuse.
Old Feb 10, 2015 | 04:47 PM
MarcDavidoff's Avatar
My shifter light usually doesn't come on when I put the lights on but I give the console a tap and it lights up. I obviously have a loose bulb or such, but yours may be a fuse if the lighter also doesn't work.
Old Feb 10, 2015 | 07:03 PM
01tl4tl's Avatar
that power outlet/lighter on dash tends to get pushed in, may have grounded out and popped fuse (note the small area next to lighter has label NOT AN ASHTRAY)
ck diy section (5th item down main gen 2 list as you entered forum after sign in
`NEW Official 2nd gen DIY blahblah` click that for the entire list of diys with direct link to each, arranged by sections- thanks to fsttyms1
since you are a new owner here are things you need to make your life much better
the owner manual - lots of important info in it- free download from acura
Acura Owners Site | Exclusive Knowledge, Service, & Benefits
and register with acura care- they handle recall notices and you may need some airbag parts! 1 800 382 2238 x5 gets a human
Need the cars VIN number for both those places
On that new radiator, follow book directions for burping the system -even it its been running, burp per book
its not just add coolant and wait a few minutes like a normal car,,few things are like a normal car on the TL!
The temp should come up in a few minutes driving to 1-2 lines below half- and stay there regardless of operation conditions. If it moves there is a problem!!
welcome to the forum, if it can go wrong, someone here has experienced it!
BoricuaTL
Apr 8, 2016 01:08 PM
dlevesque
Sep 16, 2015 10:18 AM
theinsvnity
Sep 10, 2015 10:22 PM
brjones9
Sep 3, 2015 07:30 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
