Shift Indicator Lights Problem
Old May 4, 2009 | 03:16 PM
TL-S 02's Avatar
5th Gear
I own a 2002 TL-S, wondering if this would be a problem I should have to worry about. On the dash the Shift indicator, The neutral light will not turn on, and can't start the car up when ever you shift up from Drive. But when you Shift from Reverse to Neutral the indictor light turns on, and am able to start the car. Is this a problem that I have to worry about.
Old May 4, 2009 | 04:38 PM
TL-S 02's Avatar
5th Gear
Here are some photos not sure if they will help
............................................ Shifting up from Drive.................................................. .................................................. ....Shifting Down From Reverse
Old May 4, 2009 | 04:44 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
Don't you usually start your car in "park" ??
Old May 4, 2009 | 04:47 PM
TL-S 02's Avatar
5th Gear
Yes, but I sometimes cut the power when going thru a carwash, to get under wiper blades. and i beleive all cars can be started from neutral or park.
Old May 4, 2009 | 06:27 PM
fsttyms1's Avatar
Have you ever spilled any thing like coffee or soda near the shifter? You may have some sticky contacts in the shifter. You can take out the center console and get to the shifter and clean the contacts.
Old May 8, 2009 | 08:11 PM
TL-S 02's Avatar
5th Gear
I see no signs that anything has spilled into the shifter.
This is how far i have taken the center console apart
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
HeloDown
Sep 8, 2015 06:51 PM
jordanboi
Sep 5, 2015 01:33 AM
