shaking while braking!!!! PLEASE HELP !!!!!
Old Oct 28, 2008 | 02:58 PM
99acura_POLAND's Avatar
4th Gear
Hi.i have my 99 tl since was new.now im in europe and i have this problem while braking.i have changed rotors on new,fixed the calipers,changed brake pads,new brake fluid,all the ball joints are good,new motor mounts.nothing help even if so only for a short while.i have 212 k miles on my tl.have anyone had similar problems???i have been fighting with that for so long i close to giving up already and just leave it like that.
Please help!!!!!!!!!!
Old Oct 28, 2008 | 03:04 PM
4th Gear
It seems the shaking comes from pass side.
Old Oct 28, 2008 | 03:38 PM
ZEUS'O3TL's Avatar
Low & Slow w/Dubz On My
have u checked the tie rods...
Old Oct 28, 2008 | 04:45 PM
4th Gear
ALL SEEMS FINE.i CHECKED ALL.LAST THING THAT COMES ON MY MIND IS THE AXLE.
Old Oct 28, 2008 | 08:24 PM
totaledTL's Avatar
Fixed the calipers- what was the problem & what did u do to correct it?
Old Oct 28, 2008 | 10:20 PM
Seantype-s's Avatar
How about you take the car to someone who knows what they are doing...aka a mechanic.
Old Oct 28, 2008 | 11:57 PM
SLushhYYY's Avatar
Keep It Simple in
^Hater
I had that problem aswell, but I just replaced my front rotors and the braking was smooth as can be. If you already did that
Old Oct 29, 2008 | 04:54 PM
5daddy13's Avatar
PNYXPRS
Do a search for re-bedding the brakes.
Old Oct 29, 2008 | 08:16 PM
Rajca's Avatar
wham bam thank you ma'am
did u check the tires to make sure that no belts are broken?
Old Oct 30, 2008 | 06:40 PM
Seantype-s's Avatar
Not a hater, just speaking from personal experience. I've spent hundreds of dollars in suspension parts over the summer trying to fix a shaking problem myself, replacing almost everything I thought might be contributing, and still haven't fixed the problem. Suspension is tricky, and sometimes best left to the professionals.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
prbori
Sep 27, 2015 01:37 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
