RPM pulsating on Parking and Neutral
Old Apr 8, 2010 | 08:58 AM
abhishek.bhat's Avatar
Hi guys, I have a 2000 Acura TL, i accidentally drove my car into flooded street and it stalled. I pushed it out of the water and waited for 3-5 minutes. It started after that. There was no water into exhaust pipes. Now the car is working fine on gears but in parking and neutral gears the RPMs are pulsating between 1000 and 2000 on its own. any thoughts??
Old Apr 8, 2010 | 09:17 AM
Old Apr 8, 2010 | 09:47 AM
NSXNEXT's Avatar
Clean or replace the idle air control valve (IACV) on the throttle body.
Do a search, it's been discussed a lot.
Old Apr 8, 2010 | 11:27 AM
01tl4tl's Avatar
if water came out the exhaust that would be dead motor!!
buy gasket for TB to manifold at parts store or dealer
remove the throttle body- on bottem of assembly there is a round cover with 2 screws- remove and remove the part under it- clean all - reassemble
Old Apr 8, 2010 | 02:36 PM
fsttyms1's Avatar
^ I would just take the whole upper intake manifold off and clean the EGR ports at the same time, that way when its off you can flip it upside down and take off the IACV without having to take off the TB and dont have to replace the TB gasket.
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
MikeJM310
Sep 24, 2015 07:24 PM
Brandle34
Sep 23, 2015 07:20 PM
