Rough idle after spark plug change
So I just changed out all 6 plus and replaced them with NGK Iridium IX plugs. The car start up fine but idles rough and the check engine light came on. I checked all the connections and bolt everything is tight, I'm not sure what is wrong.
Likely a bad coil, but anything is just a guess until you get the code(s) read.
Good news! I went back and triple checked everything and the rear passenger plug for the coil pack was loose. Now it runs perfect =) On a side note, changing the three rear plugs was a b*tch!
there are several tips in the diy on how to make the rears much eaiser
for those about to do the job:
a 3 and 6 inch extensions, plus a real spark plug socket are the way to go,,
slip the tool in by sections-- and there is even a bump in the firewall on pass side for your hand to fit with ratchet!
