Right way to check transmission fluid?
Old Nov 11, 2007 | 04:35 PM
jblaze06's Avatar
I know every car has different way of checking the fluid. The manual stated that you should check the fluid when the car is at normal temperature. What does this mean? After you drive for a while and check it while the engine is off? or check it while the engine is running? Or check it hours after you drove it?
Old Nov 11, 2007 | 04:46 PM
acutee's Avatar
warm up the car, or drive it for 2 min, then park, and shut off engine, now check the fluid level.
Old Nov 11, 2007 | 05:01 PM
01tl4tl's Avatar
According to my Gen2 owner manual
Drive 20 minutes at freeway cruise speed
Stop
Shut off engine
Remove Yellow handled dipstick on driver side of car
Wipe clean
Insert Fully and remove
Level should be between the 2 dots
Should not have burnt smell
mada51589
Jan 9, 2025 04:40 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
ghuns
Sep 16, 2015 04:26 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
