Right headlight problems! help!
Old Oct 22, 2011 | 01:06 AM
cindyrayy's Avatar
So the right headlight bulb just went out in my car, I got it replaced and it worked fine, then later that night when I turned my lights on, the right one popped on a little slower then the left. So I shut the lights off and turned them back on and it wouldn't come on, then I tried turning them on and off a couple more times, then it turned on, then if I shut it off again and turned it back on it wouldn't turn on. What's the problem?! Help!
Old Oct 22, 2011 | 02:58 AM
01tl4tl's Avatar
welcome to the forum
It sounds like you have the standard ballast wearout/shorted problem that many experience
Did you notice any moisture inside the headlight lens? thats death to the ballast
you did get the correct HID bulb- not some `normal` zenon or halogen bulb?
the easy fix many are doing is a full HID kit replacement with aftermarket parts- waterproof no less~ get rid of the stock stuff and enjoy
ck out www.hidextra.com as one source that ziners use, unreal low prices, very little modding needed to make it all work,,also buy 1 relay kit $15, for better wiring to lights
out the door for under 100 bucks,, and some change back to you
Old Nov 5, 2011 | 12:21 AM
blaine209's Avatar
had same problem with a new bulb it wat i get for getting some cheap ones. just get new bulb i suggest phillips yes it cost more but its worth it later down the road and also will save money as well as time
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
