right headlamp failure?!
Old May 27, 2014 | 07:48 PM
Xxb005txx's Avatar
Gabriel Alejandro Iser
Exclamation right headlamp failure?!
So I just randomly lost power In my right headlamp. I had checked The fuse and it was blown so I replaced it. Unfortunately, my headlamp is still out. I only have light coming from my parking lights. I have a slight condensation issue with my lamp as well. I can't have this damn thing lookin funny again. Help? Tickets are booming in soflo. And PS the fuse hasn't blown again so I have no clue what could be going on
Old May 28, 2014 | 07:51 AM
3.2TLc's Avatar
Lightbulb Time for an aftermarket "HID" kit.....
Originally Posted by Xxb005txx
So I just randomly lost power In my right headlamp. I had checked The fuse and it was blown so I replaced it. Unfortunately, my headlamp is still out. I have a slight condensation issue with my lamp as well. I can't have this damn thing lookin funny again.
Your old HID headlamp components are in need of replacement, ASAP to avoid a ticket.
Old May 28, 2014 | 08:40 AM
Xxb005txx's Avatar
Which components tho? I replaced with new HID bulbs not that long ago. :/ and paste night I noticed that sometimes it would start flickering on and off. So the bulb is good because it isn't dim. My guess is there must be a short or no contact with the wiring
Old May 28, 2014 | 06:23 PM
3.2TLc's Avatar
Yeah, the wiring connections.....grounds....ballast & inverter could be compromised by any moisture visibly present. Corrosion spells trouble and eventual death to our original HID's.
So, for less than $100.....consider an aftermarket replacement kit to replace the entire set-up with new troublefree stuff. Check the "DIY" sticky and past threads for installation tips.
Old May 28, 2014 | 06:28 PM
Xxb005txx's Avatar
Thanks! And is there a common place where water would leak or something? I saw a possible breach for leaks on the top of the lamp and sealed it myself with silicone gel. Problem is I now see droplets months later. :/
Old May 28, 2014 | 08:11 PM
Groovemaster's Avatar
I just bought my TL last week, and with a little rain yesterday, my right HL is filled with condensation. I called the dealer, and they pretty much said that the seal attaching the lens to the body is damaged somewhere. I was going to buy a used one from here, but I decided the best thing would be to buy a brand new one (no issues). So it arrives on Tuesday. I would try swapping your right and left ballasts (if you are able) to see if the ballast or the bulb is bad.
Old May 29, 2014 | 10:19 AM
01tl4tl's Avatar
bs on swaping parts
If you have moisture you have the same issue we all have- after 10+ years its time for some modern technology- that's waterproof!
www.hidextra.com is a trusted source for many on here and only 59$ before coupon
their `kit` has 2 ballast 2 great quality bulbs and the connector wire
all you have to buy is a $2 box of inline connector or butt splice
don't need the relay or anything else as we have hid stock- we are just swapping in new parts
suggest the standard 35watt ballast and 5000k bulbs= to best see objects you wish to avoid
Old May 29, 2014 | 10:21 AM
01tl4tl's Avatar
If replacing one housing due to moisture- the other probably has it too, or will
with those avail for about 75$ its well worth doing both sides, and both sides get the new kit parts too
Old May 29, 2014 | 11:55 AM
Xxb005txx's Avatar
Hmm. So 75 I get both or 75 each?
Old May 29, 2014 | 12:23 PM
I just ordered mine for $72 with shipping, one side only. I doubt there will be much better pricing than that for new parts. I did find a set for about $130 shipped, but I only needed the right housing.
Old May 29, 2014 | 10:32 PM
01tl4tl's Avatar
try our vendors- main list link at top of pages or pop up ads for them, several dealers give us the hookup and the ads for what is being discussed in a thread seem to appear with frightening timing.......they are watching
groove its ok to post where you got a good deal like that- help another ziner out
note: apply and buff a few coats of synthetic car wax to the lens face of the new -and sanded/cleaned old lights- that seals the lens plastic up well against road grit and wear
Old May 31, 2014 | 10:06 AM
Xxb005txx's Avatar
no way! can i get a link of the site where u guys purchased? Thanks a million to you all for your input
Old May 31, 2014 | 10:14 AM
01tl4tl's Avatar
any internet search for the housings will find the one for 75, also look in `the black market` section on here
`Sponsored Sales` is the dealers and others with new parts that hook us up
call a few if you don't see a post for the housing
our search feature works well too
Old Jun 1, 2014 | 04:43 PM
http://www.ebay.com/itm/130881027733...84.m1497.l2649
They have the right and left on different actions...use Paypal to pay, it will protect your purchase...
Old Jun 4, 2014 | 09:32 PM
indomla's Avatar
My right headlight also went out sometime back. I took the bumper off and the right headlight out.... proceeded to take the ballast out and immediately noticed that when shaken there was water swooshing and swishing around....
I bought a new headlight at Headlight Depot and new ballast kit from HIDExtra. Going to install them on the car later this week.
Jamus22
Jun 11, 2023 10:08 AM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
hpfiend
Sep 27, 2015 06:59 AM
