Replacing Wheel bearings help
Old May 2, 2012 | 02:53 PM
Freaknic713's Avatar
has anybody tried to replace a wheel bearing before? Im kinda stuck cant seem to get the bearing out from the hub. I have the service manual and it shows I need a special tool but I remember it could be done without it. I think I might be doing something wrong.
Old May 2, 2012 | 09:57 PM
01tl4tl's Avatar
ck the diy section, 3rd item down the main gen2 thread titles
OFFICIAL DIY blahblah
it its seized in there you may need a machine shops help or new part
Old May 3, 2012 | 08:51 PM
fsttyms1's Avatar
You NEED to press the front bearing out. It can be done without the special tool but still needs to be pressed out.
Old May 3, 2012 | 11:24 PM
01tl4tl's Avatar
If its bad take it to a machine shop -possibly napa has one-
or an auto shop with a press,, if you can still find one!
better to spends few dollars now than destroy the surface and new bearing
Old Jul 15, 2012 | 09:38 PM
acu23's Avatar
dude just did it this weekend it is way less complicated than i had expected i didnt have to use an air tool for the axle nut just a breaker bar (24in) everything else was pretty straight foward the only thing i had trouble with was the two screws holding the disc to the hub i drilled those out other than that super easy..Tip make sure you find a shop that has a press not all shops do..
2012wagon
Sep 29, 2015 04:21 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
heyitsvic
Sep 4, 2015 09:38 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
