Replace Gear Indicator Bulb (D5)
Old Aug 22, 2010 | 04:18 PM
BustedLX's Avatar
Question Replace Gear Indicator Bulb (D5)
Hello All,
I have a 2001 TL that the D5 indicator recently blew out on. I purchased a replacement bulb from Honda (78181-SS0-003) and attempted to replace it this weekend.
I thought this was going to be a simple pull the cluster out, replace the bulb, and reassemble but apparently not.
According to the service manual I have to remove the gauge assembly, disassemble the gauge assembly, and change the bulb.
Problem is it gives no explanation on how to disassemble the gauge assembly. From the picture in the service manual it would appear that I need to have the printed circuit board removed from the plastic casing so I'll have to remove the actual gauges (Tachometer, Speedometer, Fuel, Temp, and Information display).
Does anyone have any experience with this that they can share?
Thank you in advance for your time.
Old Aug 22, 2010 | 10:58 PM
my.daily'tl''s Avatar
Always Working In
If you've already got to the gauges you'll see the plastics tabs that hold them together. Carefully pry the tabs with a small screwdriver. There might be some more info or pics in one of the led gauges threads.
Old Oct 3, 2010 | 09:09 PM
Severin's Avatar
Did you ever replace your bulb? I had my D5 blow out in my '00 this week as well and just looked up the procedure in the service manual too.
If so, what did you end up doing?
Thanks!
If I'm in there, I might just buy the lens assembly for $13 and have it crystal clear again...
Old Oct 3, 2010 | 10:30 PM
finalcross's Avatar
http://ledautomotive.com/guide.php?id_cms=52
This site has a good guide of how to remove everything.
Old Oct 4, 2010 | 08:48 AM
Severin's Avatar
Nice site, thanks!
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
niray9
Dec 8, 2015 07:34 PM
brjones9
Sep 3, 2015 07:30 PM
