removing door panel
Old Jan 11, 2007 | 02:13 PM
White type s's Avatar
8th Gear
removing door panel
need help removing rear door panel.....took out all bolts...but won't come off
Old Jan 11, 2007 | 04:30 PM
Renli3D's Avatar
If you took out all the bolts then you need to release the clips using a trim remover tool. After that you just slide the panel up and out.
Old Jan 11, 2007 | 05:12 PM
8th Gear
can't remove the plastic piece around the door handle.....that what hold the door panel back......how do i take that off?????
Old Jan 11, 2007 | 06:04 PM
fsttyms1's Avatar
there is a screw that holds that in, then you slide it forward just enough to pop it out. Then you pop the clip that holds the metal rod inplace. there is also a screw in the door handle (large hol from underneath) after than then all you do is start at the bottom and pull out on the door panel. Its just helpd on by clips. Get them undone and lift up to free from upper part of door
Old Jan 11, 2007 | 08:42 PM
8th Gear
thanks for the help....that plastic piece was the only thing hold me back....installing new speaker
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
govtcheez
Oct 1, 2015 12:21 AM
CadiGTi
Sep 14, 2015 06:37 PM
