removing door panel
there is a screw that holds that in, then you slide it forward just enough to pop it out. Then you pop the clip that holds the metal rod inplace. there is also a screw in the door handle (large hol from underneath) after than then all you do is start at the bottom and pull out on the door panel. Its just helpd on by clips. Get them undone and lift up to free from upper part of door
BoricuaTL
Apr 8, 2016 01:08 PM
