Removing domelight and map light housings
fu
Hey I need help removing the domelight and map light housings so I can put some carbon fiber on them, but I can't figure out how they come out. anyone got any suggestions?
There are two points on the map light cover(the clear section) pry these off with a small flat head, then once that is off, put the sunglasses holder in the down position and look up, there are two screws above there, and also two screws above where the map light cover was.
This is the same piece you need to remove if you are replacing your Rear View Mirror(which i got for 15 bucks and did last week)
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
