Removing Bolt for Harmonic Balancer
Old Apr 17, 2009 | 07:48 PM
prasook's Avatar
3rd Gear
2001 TL - I am in a process of replacing timing belt and water pump. I am having trouble removing the bolt holding the Harmonic Balancer, I do have a toll to hold balancer, while trying to loosen the bolt. My question: Is this bolt "right hand threded"(turn counter clockwise when looking at the bolt to remove?) or the other way around? As the engine crankshaft turn in a clockwise direction. I am thinking I should be turning the bolt in the same direction to remove it from the crankshaft.
Please help....
Thank you.
Old Apr 17, 2009 | 09:47 PM
adamlee05's Avatar
Thread Police Chief
Hey ther Prasook, welcome to the forums! Firstly we don't actually have a true harmonic balancer, though the pulley you're talking about does look very much like one. To answer your question, the bolt is just like any other bolt with standard threading; righty-tighty, lefty-loosey It's a 19mm btw
The required breaking force to remove the bolt is outrageous. When we removed mine from my donor engine, we found it took almost 600 ft/lbs of force to break it loose. If you can get your hands on a quality 1/2" impact gun it can most likely remove it without needing the tool, though better safe than sorry.
Another option that has been done before is get a 19mm deep-angled wrench to go on the pulley, and position the other end of the wrench on the sub-frame support beam. Take out the fuel-pump fuse (can't remember which it is off the top of my head) and start tapping the key to the start position to have the starter turn the engine over at very small incremenets.
Good luck!
EDIT: I say its a 19mm, but theres the posibility its a 21mm. Don't hold me to it, I'm tired and pulling those numbers off the top of my head. ONE is right
Old Apr 17, 2009 | 11:16 PM
Bearcat94's Avatar
AZ Community Team
3G TL, but virtually identical. Check Kenndy's post on page 1 and mine on page 4.
Look here:
A-098: DIY: UR Crank Pulley info
https://acurazine.com/forums/showthread.php?t=153549
Old Apr 19, 2009 | 03:47 PM
prasook's Avatar
3rd Gear
Thank you all I got the bolt off. Has to preloaded the Braker+Cheater bar by about 1/4 of a turn.....Thanks again all. I am putting the engine back together now. Has to go find a shop with a press to compress the adjuster back in....BTW what is the torque for the engine mount bolts?
Old Apr 19, 2009 | 03:59 PM
adamlee05's Avatar
Thread Police Chief
By adjuster do you mean the tensioner? Just put itin a vice and turn it till the hole in the pin and body line up, throw a small allen wrench in it.
Old Apr 19, 2009 | 04:55 PM
Rajca's Avatar
wham bam thank you ma'am
torque is 180ft lbs for the crank pulley bolt
Old Apr 19, 2009 | 05:31 PM
adamlee05's Avatar
Thread Police Chief
Any idea on the mount bolts? Thats what hes asking for and I can't log into my alldata for some reason
Old Apr 19, 2009 | 06:40 PM
fsttyms1's Avatar
As for the tq specs for the mounts its not much. The side one is 40 and the bracket that attaches to motor is 33
Old Apr 19, 2009 | 11:39 PM
prasook's Avatar
3rd Gear
Thank you all, I am all done....anyone has recommendation for PS Belt adjustment? Started the engine, which ran great, as always, PS made a lot of noise and foaming, perhaps I "over-tighten" the belt. drove the car around the block, was hoping to bleed the PS pump. I discinnected the "S" between reservior and pump to replace timing belts. Hope I did not ruin the PS pump, not what I am looking forward to. Had to stop for the night and will loosen the belt tomorrow to see if the noise and foaming will go away. At this time should I be thinking about flushing PS fluid? Any help would be very much appreciated.
Thanks in advance.
IBankMouse
Jun 13, 2020 12:53 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Brandle34
Sep 23, 2015 07:20 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
