Remote
you can program it yourself, its not that hard, if you do a search you will find a thread that has step by step instructions. make sure the FCC ID on your old remote matches the one on ebay or it won't work.
if you look up top underneath the acurazine logo there is a search button.. comes in very handy since we have discussed nearly everything possible
i took the liberty to do the search for you
this was origionally posted by kris in an older thread so kudos to you once again
Keyless entry Remote can be program by doing the following, you must program all remotes at the same time,
else the remotes not included in the programming will not work.
Make sure the codes in the back of the new remote matches your old stock remote. Some key fob may look the same
but won't work with each other. Be sure to have all Key fobs you want working with you when you do this.
1. Turn the ignition switch ON (II).
2 Within 1-4 seconds push the transmitter lock or the unlock button.
3 Within 1-4 seconds turn the ignition switch OFF
4 Within 1-4 seconds turn the ignition switch ON (II).
5 Within 1-4 seconds push the transmitter lock or the unlock buttin.
6. Within 1-4 seconds turn the ignition switch OFF.
7. Within 1-4 seconds turn the ignition switch ON (II).
8. Within 1-4 seconds push the transmitter lock or the unlock button.
9. Within 1-4 seconds turn the ignition switch OFF.
10. Within 1-4 seconds turn the ignition switch ON (II).
11. Within 1-4 seconds push the transmitter lock or the unlock button.
12. Confirm you can hear the sound on the door lock actuators. Within 1-4 seconds, push the transmittor lock or
onlock button again.
13. Within 10 sec, aim the transmitters whos codes you want to store at the receiver, and press the transmitter
lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter
code is stores. Make sure you program all transmitters you want working within 10 seconds of each other.
Ones not included in this programming will no longer work.
14. Turn the ignition switch OFF, and pull out the key
15. Confirm proper operation with the new codes.
***make sure the serial number on the backs match.....Program at your own risk***
SinCityTLX
Oct 7, 2015 01:24 PM
