RED SRS and oil light came on
Old Dec 2, 2009 | 09:21 AM
Kobazi's Avatar
Exclamation RED SRS and oil light came on
I have this weird thing happening lately. Every time I go over a bump at medium speed the oil light and the red SRS light both come on flashing. When I restart the car they are gone for good.
Has anyone seen this?
Old Dec 2, 2009 | 09:30 AM
JDM Inspired's Avatar
if your oil light ever flashes
1. u better turn your car off
2. check your OIL ASAP!!!
Old Dec 2, 2009 | 12:15 PM
acutee's Avatar
Try to see if you have any code.
Old Dec 2, 2009 | 12:54 PM
Kobazi's Avatar
I checked the oil and the level is perfect, in terms of the codes can I check after or at the time it occurs. The reason being is that once I turn the engine off and start again i never see it again. Also the issue is very sporadic
Old Dec 2, 2009 | 01:00 PM
acutee's Avatar
You can check it after. All codes are stored until they are being erased by losing power or with code reader. I have heard about oil position sensor or could be oil pump, but better start off with the code.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
wusty23jd
Sep 24, 2015 11:41 AM
Allen_442
Sep 8, 2015 06:01 PM
