??? Rear main seal ???
Old Mar 25, 2011 | 09:07 PM
dan lazer's Avatar
~~~ SKY'S THE LIMIT ~~~
i know there was a trend about a oil leak and i have a oil leak as well---pretty sure its the REAR MAIN SEAL
so i want sum opions here on what you guys think
i seen at auto parts stores they have this stuff for rear main seal leaks---you add it in the oil when ya change it
sooo im just asking what you guys wud do if it was yer car that had a blown rear main seal ????
im no mechanic and need sum advice
what brand wud you chose---LUCAS or BARS LEAK ??
THANKS GUYS---MUCH APPRECIATED
Old Mar 25, 2011 | 09:10 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
I would change out the seal. Yes, it's less than a $10 part, and the labor is hundreds of dollars, but it's a permanent fix.
Old Mar 25, 2011 | 09:12 PM
riicky's Avatar
6MT
i got an 04 TL 6MT and my rear main seal is leaking. not sure if lucas or anything would stop the leak but i heard your not suppose to use lucas in engine. if you have to get it done it will be a expensive one!
Old Mar 25, 2011 | 10:33 PM
bl3ujay07's Avatar
ftmfl
Old Mar 25, 2011 | 11:08 PM
dan lazer's Avatar
how come yer not suppose to use lucas in engine---the lucas stuff is made for the rear main seal leak
Old Mar 25, 2011 | 11:12 PM
dan lazer's Avatar
i know putting that stuff in is not a permanent fix---i really dont have the money to get it fixed right now
i guess im looking for a temporary fix for the moment till i can afford to get it permanentley fixed
just wondering if putting that stuff in is bad for the engine
Old Mar 25, 2011 | 11:14 PM
dan lazer's Avatar
Originally Posted by bl3ujay07
ftmfl
what does "" f t m f l "" mean ???
Old Mar 25, 2011 | 11:33 PM
gold2003tl (90)'s Avatar
2003 TL-p
For The Mother F-ing Lose
id stay away from Lucas products, they tend to just thicken the oil and over time gunk things up. but then again iv heard people having good luck with Lucas. its pretty much a last resort and a hit or miss.
Old Mar 26, 2011 | 01:02 AM
dan lazer's Avatar
^^^ thanks man---appreciate the info
did ya ever hear of anyone using it for a rear main seal leak
and also---what if i use it just to seal up the leak---then change the oil again
do ya think that will work ????
Old Mar 26, 2011 | 11:07 AM
01tl4tl's Avatar
go to each makers website and read the tech details and how to use properly.
then do a search for the product name + reviews or +comments
you should find plenty of info on the internet
I saw the special `rear main stop leak` on a speed tv program recently, iirc `2 guys garage`, (ck speedtv website-links etc) and while they are doing advertising- they did seem impressed with the product-
something different was in it than the normal engine seal stop leak--
specific to the rear main ,,
or at least great marketing of the same old stuff
assumedly for use in emergency low cash flow situation, old chevys with notorious leak etc
why some dont like lucas engine treatment and not for the TL: it tends to foam easily and aerate, not good for the general operation of the oil
In many other engines it would be fine
We have vtec- which operates off changes in oil pressure, so you want clean easy flowing fluid going thru the many tiny oil gallies of the engine
Old Mar 26, 2011 | 03:38 PM
dan lazer's Avatar
^^^ understandable man
i was just at the dealership and a few of the techs said the exact same thing u said !!!!!
im definetley not gonna use that stuff----i'll just get it fixed the right way and be done with it
!! thanks for the info guys---i really appreciate it !!
Old Aug 23, 2011 | 11:24 AM
soxfan62's Avatar
5th Gear
Hi, new '99 TL owner here. Car has ~160k miles on it. Unfortunately, I'm very likely to need to get the rear main seal replaced. I'm hoping to get some advice on what other things I might want to have replaced once the tranny is out of the car, so that i can hopefully avoid any other problems that will involve 8-10 hours of labor to replace a $50 part.
Thanks.
Old Aug 23, 2011 | 12:44 PM
01tl4tl's Avatar
first
ck the pcv valve above rear valve cover- near the throttle cable end of engine
remove and shake- a ball like device should move freely
If it doesnt you may solve the oil leak with a ~10$ part
when that vave is sticky or stuck- internal engine pressure has no escape-
the easiest path for it becomes `thru the rear main seal` where it pushes some oil too
Definetly worth removing and testing of that part
read this thread-- as he figures out the actual problem
If its really the rear main- thats all there is inside! the trans is a sealed unit
they can change fluid while its in the shop
trans remove and replace Labor should be 4 to 6 hours depending on the shop,
maybe charge you an extra 30 minutes to remove flywheel and replace seal
rear seal is not 50 dollars! where did you get this estimate! dont use them~
Old Aug 23, 2011 | 02:43 PM
soxfan62's Avatar
5th Gear
Thanks for the advice on checking the PCV valve. I'll do that.
What I meant about other things was not so much tied to the rear main seal job itself, but whether there were other things that could be checked and possibly replaced while the tranny was already out.
As for the $50 number, not entirely sure where I got it. I thought it was from a different thread either on here or on the Accord site, but it wasn't from a shop. In fact, when I had the car at Honda yesterday, they estimated ~$1000.
Old Aug 23, 2011 | 05:08 PM
my.daily'tl''s Avatar
Always Working In
On the 99 the filter is inside the casing but you can clean the solenoid screens. That will be easy with the tranny out.
Old Aug 23, 2011 | 07:04 PM
dc2kid's Avatar
hey i have a leak to but i was told its the oil pressure switch did you check yours?
Old Aug 24, 2011 | 10:56 AM
01tl4tl's Avatar
op sensor would leak engine oil
thats why they color fluids- to identify them
thegipper
Oct 21, 2015 07:19 AM
IIDXholic
Oct 8, 2015 07:53 AM
Sep 21, 2015 08:44 AM
Sep 17, 2015 09:01 PM
Sep 17, 2015 08:57 PM
