random clicking from turn signal?
ok.. so i started noticing this a couple weeks ago and its just freakin weird.. you know the clicking sound you get when you have your blinkers on right?.. and you know how its a fast clicking when one is burned out?.. well recently there has been a random fast clicking like a bulb is burned out, only there are none burned out and my turn signal is not even on.. so uh.. wtf??
like i said.. its making this noise when i have no turn signals on whatsoever.. i could understand if it was randomly fast when a turn signal was in use and i would check the connections, but its doing just the clicking noise when there is no signal being used.. when i get off work tomorrow ill see if i can make a video of it or something (if i can figure out how to upload the shit from my phone)
B A N N E D
but is there any specific time you are hearing it; like hot/cold ambient temp; engine is hot/cold, right after you start the motor or you have been driving at least 30 minutes or so, etc, etc.
kinda need more info
is it the evap purge solenoid (on the driver side strut tower) you are hearing, cause it is resonating through the car???
B A N N E D
its definitely coming from the turn signal stalk area.. it only did it a couple times today though.. the sound on my phone is shit, so i couldnt get a decent vid.. while trying to record it in my driveway, i could only trigger it by turning on/off the signals.. it just seems like maybe the relays are sticking or something.. not sure how everything works down there so i dunno.. ill try using my digicam later to see if i can trigger it and get better sound..
only things that i can think of that might be in the steering column area that might make a similiar nose to a relay clicking might be the ignition switch contacts arcing (if so, you will find out shortly if that is it), or maybe the solenoid for the key interlock (so you can only pull the key out with the car in park)
well i always just assumed the clicking came from the stalk since it was related to the signals.. it is definitely the exact same clicking that occurs while the signals are on.. just more random and faster here and there.. ill look more into it tomorrow when theres more light..
ugh.. so it seems to be more of a weather triggered issue.. on wednesday (got up to fucking 70 here) it was hardly doing it at all.. cold front came in that night and the past fews days have been very annoying.. im just gonna have to find the relays and probably just replace the damn things.. really irritating..
B A N N E D
so i know im probably just going to replace the relay in the next couple days, but i went ahead and made a video a bit earlier when i got home.. crank up the video players volume and adjust your speaker volume accordingly..
http://s12.photobucket.com/albums/a2...t=03e84058.flv
you can hear it enough to realize its there.. its a fast click like as if a turn signal bulb is out.. and i can take the video like you said, but you definitely wont be able to hear the clicking.. i had my phone right next to the panel just below and to the left of the steering wheel.. plus, when i panned down to the relay, i turned off the blinker.. so theres nothing to see anyways..
so its definitely the flasher relay that is clicking like mad.. i went up to the dealer near work just to see if they had a clue what it might be.. the guy that "helped" me looked at me like i was a fucking moron the whole time.. i asked if it might just be the relay sticking somehow and he says "well, some of these cars dont even have the actual flashers anymore, so it might be in the stalk".. umm.. what??.. then he promptly asked if i wanted to leave the car there.. i said no, which led to the "do you want to make an appointment?" and i said "umm.. no.. ill just check it out at home".. still looking at me like a moron, he walked off.. this was one of the retard service guys that have probably never touched a car in their life.. at least back at honda the service techs actually made a point to get a shop guy to come out with them to check out any problem i had.. ugh..
so i guess im just gonna buy a new relay tomorrow after work and see what happens.. if it doesnt fix it, ill ask my buddies at honda to check it out.. im only out like $12 for the relay anyways, plus itll definitely not be the problem if they do check it out..
so a faaaaaaaaaantastic turn of events today.. met up with a friend for lunch and was telling him about my issues.. got to the restaurant and started seeing what was flashing, what wasnt, shit like that.. looking closer, with the signals off but clicking like usual, the left indicator on the dash was faintly flashing.. so i went out and sure enough, the signal was barely flashing too... it would do it intermittently when the right signal was on also.. so after saying "fuck it, lets eat" we finished our meal and started messing around with the signals again.. while sitting there trying to figure it out, the fucking signal stalk started to smoke.. ugh.. so when the clicking was occuring by itself, the stalk would smoke, which meant it would be smoking all the fucking time.. so i just pulled out the relay for now and currently have no signals.. heading to the dealer tomorrow for a new stalk and hoping to hell that it will be fixed..
i went directly after work and the guy said that he has never had to order that part, so there wasnt one in stock.. he told me i might be able to hit up a parts store and they would be able to cross reference the numbers on the relay if i didnt want to order it.. i decided to put that off until after lunch, which is where, as mentioned in my previous post, i noticed the smoke and funky flashing problems.. this has put the relay on hold because it obviously was NOT the relay that was smoking..
Oh...Behave!
I have a 2001 CL and I just noticed a faint ticking/clicking relay-type sound that seems like it's coming from the left lower area of the steering column. It's not nearly as loud as yours is and only seems to do it while I'm cruising along the freeway at around 80 mph and steering slightly right or left to stay in the lane.
Please let us know what you find out!
so i went bought the combo switch on saturday and started the dismantling.. had other shit to do and it was cold as fuck, so i didnt do much.. did more on sunday, but ran into an issue trying to take off the cable reel behind the steering wheel.. went to acura today and talked to a couple of the shop guys and they told me that there is another hidden clip that the manual doesnt mention.. got home, found the clip and the rest was smooth sailing.. swapped out the combo switch, put everything back together and tried it out.. NO CLICKING!.. plus the switch is a SHITload quieter than the other one..
after everything was double checked and tools put away, i went inside for the disection of the old combo switch.. here is what i saw.. the dark areas are burnt to shit and smell horrible..
im at a bit over 118k right now.. when i mentioned the quietness of the new switch, i mean there was a serious difference.. i noticed it seemed a bit louder than usual when i bought the car, but being that i didnt know the car, i figured it was kinda normal.. now that i have heard the way its SUPPOSED to sound, im thinking somewhere down the line the previous owner may have damaged it in some way.. but i dunno.. i got it all situated and shouldnt have to worry about it anymore for quite a while..
B A N N E D
i was kinda thinking the same thing, cause that does not seem normal at all, maybe they liked to be those idiots that you see driving down the road with their blinker on
also did that stalk ever seem to be loose/have play in it
and normally when they go bad, it is normally the headlight switch on that stalk, or is basically hanging there, or has alot of play in it
it seemed to have a bit of play, but it didnt stand out as much as how loud the thing *clicked* when engaging the signals.. it literally sounded like something was cracking or something each time..
no play or anything in the headlight portion though..
and as far as the previous owner, he was a friend of mine.. cool guy and all, but honestly didnt really know much about cars at all.. so i wouldnt put it past him that he might have screwed something up by either pulling up or down too hard or forcing it some other way..
aaaaaanyways.. those days are over.. now i gots my new shit and hopefully troubles in that area are behind me..
on to the next one...
I am having the exact same problems with my 2001 CL-S you were having. I swapped out the Signal Relay for a new one from the dealer, but no dice. Same issues continue to occur and they dealer is NO help WHAT-SO-EVER. So, can you please explain this "combo switch" in better detail? Do you have a part # by chance? Where exactly is it located? What does it look like?
My local dealer wants two hours labor and $100 in parts to "maybe" fix it. Pass.
Thanks in advance for any help you can lend me.
I'm going to need to bump this and hope you're still around...
it should be roughly the same setup as mine, so let me know if you need any pointers or copies of the manual to look at..
09-17-2015 09:01 PM
Greengecko
09-16-2015 08:19 PM
