Alignment Issue
Old Mar 22, 2010 | 01:16 AM
Charles Martinez's Avatar
Alignment Issue
Went to NTB today to take advantage of the free wheel alignment and brake check and they told me that the rear camber can not be ajusted. my passenger side wheel is wearing on the inside and that i would have to take it to a place that fixes frame. has anyone had this problem?
Old Mar 22, 2010 | 01:19 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Hey Charles. Regarding the P/S wheel, this could be the result of a previous collision.
Regarding the rear, NTB is right. The camber cannot be adjusted. If you are lowered, you can make up for the lack of camber adjustment by installed a camber kit, or asking the alignment tech to dial in negative tow for you in the rear.
Old Mar 22, 2010 | 01:27 AM
That could be true cause i purchased it used over 6 years with 30,000 miles on it.right now its not lowered but i want to correct this issue before i buy some rims and tires for it.i will be going with 18 inch package
Old Mar 22, 2010 | 02:00 AM
If your suspension is bone stock, and the alignment shop is saying that they can't bring it back to OEM specs, that sounds like trouble. Go to another alignment shop, and ask them about it. Also, ask them to give you a printout of the specs after the alignment.
Old Mar 22, 2010 | 02:07 AM
Yea i am going to get another opinion before i spend any money on wheels but we will see.thanks for the feedback.
Old Mar 22, 2010 | 02:09 AM
I hope I helped. Keep us updated.
Old Mar 22, 2010 | 06:54 AM
fsttyms1's Avatar
Get a 2nd opinion, and if you are having wear on your tire because the alignment specs are out of spec you probably have something bent and you will need to find what needs to be replaced.
Old Mar 22, 2010 | 04:31 PM
Thats exactly what NTB said that it might be bent so i would have to take it to a shop that specializes in bent frames or suspensions.I will get back as soon as i find out what was wrong.
Old Apr 19, 2010 | 07:52 PM
Sorry i took to long getting back but it turned out being a bent trailing arm on the right rear suspension.the shop used some type of jack and got it back but told me to keep a eye on it,also to bring it back so they could check it.i spent 150 on the labor and alignment,they also told me if i replace the part they would install part and do another alignment but only charge for the labor since they didnt completely fix it.
Old Apr 19, 2010 | 10:04 PM
Nice. So are you going to replace the part?
Old Apr 20, 2010 | 03:19 PM
Yea as soon as i get more funds im going to but wouldnt you know when it rains it pours,when i was attempting to get that issue fix found other things.long story short i have 4 months to replace the catalac converter for my inspection and i need motor mounts all of them.
Old Apr 20, 2010 | 03:23 PM
Sorry. Motor mounts are known problem areas in our cars.
Old Apr 20, 2010 | 06:59 PM
Yea i used to own a 94 accord and i needed them too but still since this my 2nd honda i would still recommend them.i bought my 99 tl used with 30k miles on it and im at 130k and just now having issues with it.
Old Apr 20, 2010 | 09:20 PM
dykyy's Avatar
In U.S you have to go to some sort of a state government regulated shop to do your e.test and safety? Or is it just a licensed shop?
Old Apr 21, 2010 | 09:29 AM
I used to go to a regulated shop but the last 2 times they it not pass because of my tint so i went to a place across the street from them and didnt have any problems.another shop told me he would turn off the check engine light but i should have it fixed by then. im looking at a little over $300 to replace it,if i go to the dealer well you know that wont happen they want a arm and leg.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Zonian22
Nov 14, 2015 01:20 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Sep 14, 2015 10:09 PM
Zonian22
Sep 2, 2015 08:19 AM
