Radiator Fan Problem
Ok, so its been pretty hot here in SoCal lately. The other day when I shut down the car (took the key out of the ignition) the driver side radiator fan stayed on. This has happend before and so I didn't mind it. However after returning to my car in an hour or so, the fan was still on. Fearing that it would drain my battery I unplug it whenever I turn off the car and plug it back in when I drive. I don't know whats wrong. I hope you guys have some ideas. And yes after I let the car cool down and its not too hot outside (night time) I tried plugging it back in, and it turns on instantly.
go to www.autozone.com or www.kragen.com and look up price for part and one of those sites has a parts location guide- shows where it goes, should be no big deal
I fixed the problem. THnx for the replies guys. Im just posting just in case that anyone else has the same problem. So I got to thinking what if it was an electrical problem, because it would still run when the engine was already cold (i.e. idle for one night). So I checked the relays. Thats where I found the problem. With the help of an electrical tester, I found that the cooling fan relay was stuck on the closed position. The next day I went to the PepBoys but they didn't have it, so I went to the stealership. The part was only about 8 bucks so it wasnt that bad.
SidhuSaaB
May 30, 2020 12:40 AM
