Radiator Fan Problem
Old Mar 12, 2007 | 05:22 PM
Tanginaglaz's Avatar
Certified Rageaholic
Ok, so its been pretty hot here in SoCal lately. The other day when I shut down the car (took the key out of the ignition) the driver side radiator fan stayed on. This has happend before and so I didn't mind it. However after returning to my car in an hour or so, the fan was still on. Fearing that it would drain my battery I unplug it whenever I turn off the car and plug it back in when I drive. I don't know whats wrong. I hope you guys have some ideas. And yes after I let the car cool down and its not too hot outside (night time) I tried plugging it back in, and it turns on instantly.
Old Mar 13, 2007 | 10:57 AM
acutee's Avatar
Sounds like the fan thermo switch is bad. when it cools down the switch should switch to off, but it didn't.
Old Mar 13, 2007 | 12:39 PM
fsttyms1's Avatar
Old Mar 13, 2007 | 03:14 PM
Thnx for the response. Is it easy to replace this? Can do it myself.
Old Mar 13, 2007 | 03:25 PM
01tl4tl's Avatar
go to www.autozone.com or www.kragen.com and look up price for part and one of those sites has a parts location guide- shows where it goes, should be no big deal
Old Mar 22, 2007 | 06:09 PM
I fixed the problem. THnx for the replies guys. Im just posting just in case that anyone else has the same problem. So I got to thinking what if it was an electrical problem, because it would still run when the engine was already cold (i.e. idle for one night). So I checked the relays. Thats where I found the problem. With the help of an electrical tester, I found that the cooling fan relay was stuck on the closed position. The next day I went to the PepBoys but they didn't have it, so I went to the stealership. The part was only about 8 bucks so it wasnt that bad.
Old Mar 22, 2007 | 09:03 PM
01tl4tl's Avatar
Good Job
How bout a pic or description of where it was located and how you tested it.
When the next person uses search they will have a complete answer.
Old Jun 27, 2007 | 02:50 PM
StorkPKP's Avatar
Anyone know how to perform the relay mentioned above?
Old Jun 27, 2007 | 03:04 PM
fsttyms1's Avatar
http://www.autoshop101.com/trainmodules/relays/101.html
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
