Rack N Pinion Leaking
Old Nov 14, 2011 | 01:26 AM
blaine209's Avatar
Well my rack is leaking from main part to steering wheel Its coming down from the rubber piece i will take a pik to show you is it worth fixing if i can or do i just get a new one how do i go about this problem
Old Nov 14, 2011 | 01:44 AM
blaine209's Avatar
Old Nov 14, 2011 | 01:47 AM
blaine209's Avatar
So it is coming from inside some were in that rubber piece surrounding all around tha top of rack.The other side as well i no its not one of the other connections you see.so what do you think it could be a easy fix
Old Nov 14, 2011 | 01:58 AM
01tl4tl's Avatar
is that boot at the end of the pressure section of the rack?
peel it back and ck for fluid getting past the internal rack seal
Old Nov 14, 2011 | 02:02 AM
blaine209's Avatar
Okay i dont have my engine in so i cant really see if any more will leak but i no its coming from inside that for sure
Old Nov 14, 2011 | 02:03 AM
blaine209's Avatar
But it does sound like wat ur saying so what should i do or wat can i do
Old Nov 14, 2011 | 08:12 AM
fsttyms1's Avatar
Find what is leaking and fix it.
Old Nov 14, 2011 | 09:51 AM
01tl4tl's Avatar
if the end seal is blown, it will have fluid sitting inside the boot,
doesnt need pressure to show existing problem
Old Nov 16, 2011 | 03:33 AM
blaine209's Avatar
Well i stuck my finger and yes it there is fluid inside the boot of the pik i have up.So is it worth fixing. If i can or worth getting another rack
Old Nov 16, 2011 | 03:35 AM
blaine209's Avatar
guessing its the seal your talking about
Old Nov 16, 2011 | 10:48 AM
01tl4tl's Avatar
Ive never heard of anyone fixing a leaking rack
usually by then its got internal crud problems from the fluid never being changed
its a bit of work to remove and replace but can be done
iirc fsttyms1 did it
anyone else with personal experience- link to thread-- suggestion of store for purchase?
ck rockauto.com and NAPA auto parts
Old Nov 16, 2011 | 10:49 AM
01tl4tl's Avatar
seach internet for steering rack repairs
Old Nov 16, 2011 | 10:18 PM
blaine209's Avatar
Old Nov 16, 2011 | 10:20 PM
blaine209's Avatar
Now what i dont get where was it leaking from is the leak prob when i put it back in but the fluid doesnt do through that top top that just connects to wheel rite.or am i wrong.
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
