Q?- Non-synthetic to Synthetic?
hi i bought my car used at 45k miles and my last oil change i got done at the dealer..
should i assume that all the previous oil changes were with regular oil?
i am now up for an oil change and i feel the urge to switch to synthetic oil.
my question is, i read a member saying from switching from non-syn to syn, there will be less then optimal results. is this true?
and if so, can anyone suggest a product i need to flush/clean before my syn. change?
thanks
thanks
some guy, i forget who, on the board said there will be a lot of deposits left over and such, and that the synthetic will not be able to clean it out.
is that true?
i dont know if i should make the change or not.
thanks.
is that true?
thanks.
Synthetic oil WILL clean out those deposits. It might take it a while if there is alot, nevertheless it still will. If you use Mobile1 get the extended mileage.
When I had my Lincoln way back I switched to synthetic at 150k. Within 3 weeks I removed the oil filler cap off the valve cover & noticed that the lifters where not black anymore! Since I didnt use a flush I had to change my oil twice in two months. When I sold it, it had 350K & its original tranny
yes another member stated that. there is no need to do a flush, but you can if you want. Most that have switched never flushed including myself and i have seen great results with the synthetic
Originally Posted by merkin110
What are the major advantages of synthetic?
lanechanger
10-13-2015 10:56 AM
HydrasunGQ
09-14-2015 10:14 PM
asahrts
09-04-2015 05:55 PM
