Problems with rear brakes......
Old Nov 3, 2005 | 01:26 PM
BuDDaHz TL's Avatar
DrAnKin HeiNeKeN
My rear brakes are making noises everytime i brake. It is not the rotors sqeaking or anything, but when i brake it sounds like somthing is hitting on rear brakes. I jacked the both rears up today and applied the E-brake on. For some reason the wheel can still turn about a half inch and when you apply the E-brake the wheel should stay still completely. I also took the rear rotors out to see whats wrong, but I don't see nothing at all. Anyone know what the problem can be???
Old Nov 3, 2005 | 01:27 PM
BuDDaHz TL's Avatar
DrAnKin HeiNeKeN
Oh yea.....I did replace the rear rotors with some brembo slotted....
Old Nov 3, 2005 | 01:54 PM
optomos's Avatar
I=X - optomos
E-brake has to be adjusted after what you did. Search the forum for the how to.
Old Nov 3, 2005 | 02:22 PM
nayyarn's Avatar
Desi Pride
Did you check you brake pads.? When the rear pads where down. It makes a slight noise when you brake.
Old Nov 3, 2005 | 10:44 PM
BuDDaHz TL's Avatar
DrAnKin HeiNeKeN
Talking
I just adjusted my rear rotors and guess whatt.......it worked....brakes are silent now when I press on them. Thanks OPTOMOS. I went to search this forum and I found out how to adjust the E-brakes. I adjusted the rotor part first and then adjusted that E-brake link inside the car. This forum is the shittttt mann...... ......thanks everyone......
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
d.lim
Sep 15, 2015 08:54 PM
brandnewcolony
Sep 12, 2015 10:39 AM
