pressure valves
Get some parts/carb cleaner pour it in a bucket/container and soak the ends of the parts in it for a while to loosen. Take off any parts/screens and clean with spray can of carb cleaner or similar. Dont use pressurized air as you can damage the sensor.
The bolt onto the transmission with 10mm bolts. If there is buildup it will help your transmission shift better. If your transmission is slipping, and not just jumping gears, then cleaning the valves will likely do nothing to help you.
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
