power steering pump noise
Old Feb 17, 2006 | 02:21 AM
prjctTL's Avatar
my friends 99 tl is making a p/s pump noise. makes a whining noise when fully cranked to the left or right. could it just be air in the system?? any way to bleed the pump?? fluid is full. anybody else got this problem? should he go with a used part or purchase new??
Old Feb 22, 2006 | 12:04 PM
acutee's Avatar
the pump is worn out. One cheap way to check is try to suck out the old fluid from the reservoir and refill it with the new fluid. if it is better, then do a full flush. If not, then replace the pump.
Old Feb 22, 2006 | 03:08 PM
TunedTL's Avatar
Initial D
How do you flush PS fluid, I don't think there is a drain plug...
Old Feb 22, 2006 | 03:45 PM
acurabum's Avatar
Buy 2 bottles of Honda PS fluid then run your engine warm ...
Remove the bottom hose of the PS fluid reservoi slowly to let
the old fluid out slowly .... as old fluid goes out slowly add new fluid
from the top ......
Two bottles Honda PS should be enough to flush the system.
When finish turn your steering wheel from complete right to complet
left to bleed air inside the system ( if any ).Good luck
Old Feb 22, 2006 | 03:48 PM
acurabum's Avatar
Engine has to be running when you bleed the system .Forgot to tell you that.
Old Jun 8, 2006 | 02:08 AM
TunedTL's Avatar
Initial D
Thanks, how often should we replace PS fluid? Service manual does not have a recommendation.
Old Jun 9, 2006 | 03:03 PM
acurabum's Avatar
Only once every 2 years = 35-40k miles
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
asahrts
Sep 4, 2015 05:55 PM
