Power Steering Pump Leak Fixd with GUNK
Old Aug 9, 2008 | 08:09 PM
PaulTX's Avatar
I have 99 TL with 150K miles. Dealer pointed out slow leak from PS pump seals, said PS pump needed to be replaced. I could see the fluid discoloration on the engine components below the pump. I monitored loss of PS fluid and it emptied the resivoir in about 3-4 months so I learned to top it off as needed. Then I found Gunk PS fluid and leak stop (for Honda's) and figured I'd try. I used turkey baster to suck out old fluid and replaced with fresh. Old fluid was dark and murky. I did this three or four times over period of 6 months. I never did actually drain because I didn't know how to. Now, there is no fluid loss at all after 4 months. I am very pleased.
Paul
Old Aug 12, 2008 | 10:16 PM
totaledTL's Avatar
Probably just something in it to cause seals to swell, like old trick of adding a bit of brake fluid.
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
asahrts
Sep 4, 2015 05:55 PM
