Power steering o-ring kit colors
Old May 2, 2025 | 11:16 AM
lowpost999's Avatar
Anyone know which color B or R o-ring is for the pump and high pressure line fitting?
Old May 5, 2025 | 08:34 AM
TheMightyQuinn's Avatar
Registered Nonmember
Not sure about color, i just replaced one o-ring at a time and set them side-by-side to make sure the new is identical to the old one.
Did you buy a set with all the o-rings like on rockauto?
Old May 5, 2025 | 10:39 AM
lowpost999's Avatar
Yep eBay. I changed them years ago and it didn't solve the issue. It be even whining for years and requires a monthly replacement of about a third of the reservoir replaced. I'm gonna drain the rack, replace the return hose and rings again, fill with new Honda fluid and bleed .
Old May 5, 2025 | 11:01 AM
Google the part number or search an OEM vendor website for either #17
Or #23 below and you should find the differentiation of the colors & thus your answer?
Old May 5, 2025 | 11:24 AM
John from PA's Avatar
Usually black is the high pressure fitting and what you are calling red (some people say orange) is the return line.
austinw2000
1G TSX Problems & Fixes
Feb 17, 2016 09:12 PM
Prufessor_Oak
Jan 11, 2016 11:55 PM
dcsweet
Jun 14, 2012 10:44 PM
jbacura
Oct 23, 2010 04:12 PM
AcuraCl1
Jan 26, 2005 11:20 AM
