power locks only work when car is started.
Old Sep 18, 2012 | 01:53 PM
laid67's Avatar
Alright, I had my battery die in my 2000 tl a few weeks ago and have been faxing a ton of issues. but this one i can't seem to fix. When the car is running the power door locks work fine. the switches work on all 4 doors. when the car is off none of the switches work and i have to individually lock or unlock each door. pain in the ass . any ideas?
Old Sep 18, 2012 | 06:00 PM
3.2TLc's Avatar
Does the "keyless entry" fob work ? How about when you put the main key into the driver's
side door lock.....does it energize all 4 door locks to work ?
Recheck all battery cable wiring connections, especially the ground.
Check fuse #9(7.5a) located in the driver's side fuse panel, fuse #13(7.5a) and fuse #6(20a) in the passenger panel. There's a relay also.
Old Sep 18, 2012 | 06:36 PM
dreem1er's Avatar
deal with it
Just blame the gremlins
Old Sep 19, 2012 | 02:50 AM
HondaProtegeX2.3's Avatar
B A N N E D
yupp. check the key fob see if the red light lights up as you press the button. if not take the battery out and replace it with the same exact type.
Old Sep 19, 2012 | 07:45 AM
dreem1er's Avatar
deal with it
By manually do you mean hit the unlock button on the door, use the key in the door, or pull the lock up?
Old Sep 24, 2014 | 03:57 PM
laid67's Avatar
Sorry I never got back to this. In case anyone has the same issue I was referring to using the switch by the door handle. Turned out the problem was a burned out fuse. I don't remember which one it was. I think radio or something. It was also causing the dome light to not work, and the doors should all lock when you manually. Koch the driver's door
Old Sep 24, 2014 | 04:40 PM
3.2TLc's Avatar
^^^ Thanks for checking back in with the solution.
Old Sep 25, 2014 | 10:47 AM
TLer trash's Avatar
^^^What he said. There are way too many threads where a lot of people offer help, and the o.p. never returns.
Old Oct 24, 2024 | 02:28 PM
Jahred Sanborn's Avatar
Found another fix
Fuse position 13 clock back up was missing out of fuse block on passenger side dash 7.5a when I put a fuse back in, my clock works again, power locks work without key in ignition, my key chime sounds in car and I can manually lock all doors by locking driver door with key.
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
tonio
Feb 5, 2019 05:43 PM
